Nitrogen gas fill
#32
#33
Official Rennlist Snake Slayer
I have a compressor in my garage set up specifically for 78% N. It has a water trap that has yet to ever have any water in it.
At 8% humidity here in AZ most the time, I'm not concerned about my TPMS sensors nor the inside of my wheels corroding.... Unless you're topping off with a garden hose, how much H20 is inside the tire?
Water doesn't corrode without O2 present - which is a more sustainable argument for N, not that there is one.
#34
Still plays with cars.
If you see a 7 lb pressure increase with Nitorgen in your tires, you probably have Winter Nitrogen, and need to change to Summer Nitrogen as soon as possible
#36
#38
Tire guy mounts and pops bead with shop air. Pulls hose and lets all air out, fills with N to max tire pressure, again pulls hose off and lets most of the N and shop air mix out. Inflates to desired pressure with N. I keep a N cylinder in my autocross trailer just for that.
#39
In the aerospace business we are seeking 100% nitrogen so that in the ultra cold environment of high altitudes and/or space no moisture is captured inside a tire that can freeze up and cause issues later. Nitrogen provides a more stable pressure. Trust me, when an aircraft tire is mounted and filled with nitrogen, it's done a lot differently than any passenger car wheel and tire.
As my own dollop of fuel on the fire, when they tell you a nitrogen fill protects the tire from oxidizing inside, you might think about the oxygen outside as mentioned, but you also might ask yourself how many years you expect those tires to survive on a car driven like ours. Of course, you might be working in an auto museum and be planning to seal the car in a purged atmosphere. In which case,
Incidentally, I suspect my tires are slightly higher in nitrogen than the outside atmosphere because our dealer does a 'free' nitrogen fill and that's who mounted the tires. I have noticed the transient response is improved on roads with rippling. (No I haven't. That was a lie. See? Full of hot air just talking about this.)
Gary, who so rarely posts on a subject frivolous enough to permit use of those silly icons that he couldn't resist the chance
#40
The race teams use top tier nitrogen,that is the only kind that makes a difference,not street grade.
#42
#45
