Nitrogen gas fill
Nitrogen gas fill
So, what does anyone of know about filling the tires with Nitrogen gas? I got suckered into it today at my 15k mi service. Is it a scam? 50 bucks with lifetime guarantee..."just bring it by anytiime...."
Former Vendor
Nitrogen keeps it's pressure longer in the tire, and is drier. It's not a waste of money if you like the piece of mind knowing that you won't have to check your pressure as much with it in the tires. Racers use it because there isn't as much pressure fluctuation due to temperature changes in the tires with it. If they were willing to give you lifetime top-offs with it, it wasn't a waste of money.
Air is a mixture of gases - 78% nitrogen and 21% oxygen - with traces of water vapor, carbon dioxide, argon, and various other components. So, you paid $50 for a wee bit more N and a little less O, and maybe a little less H2O.
We're all free to spend out money as we choose.
The $50 is really just covering the labor, not much expense in the nitrogen. Nitrogen is a very good idea in wheels with tpms in them because it is very dry. Moisture in tires air can corrode the sensors and cause premature failure.
Your using Nitrogen in your tires was not a waste of money. Where you bought it might be. My Porsche dealer installs it for $20 all four tires with unlimited refills. Some Discount Tires locations have the same deal.
I use Nitrogen in all my tires. The main reason is it does not corrode the wheels and degrade the tires. Oxygen is very corrosive to the rubber and it will seep out over time. Nitrogen molecules are larger and cannot seep through.
You should know, the Air Force uses Nitrogen in all their aircraft tires because the gas is inert and in cases of heavy braking, when the wheels heat up, the gas does not expand and if a tire blows it reduces the oxygen available to the fire.
Check out Jay Leno on Nitrogen: http://www.getnitrogen.org/n2study/video/leno.html
Nitrogen in tires is the biggest scam ever. Airs is mostly nitrogen and any oxygen in the tiresfrom air will not degrade your tires or the performance of your tires. The biggest enemy of tires is ozone and that is on the outside of your tires. Nitrogen as with all gasses expands when heated up. I don't know where some of you folks read this stuff but if nitrogen is free... fine... if you must pay for it... well... it's your money. Keep the receipts with your pet rocks.
oh, and no flammability is not why racing teams use it, pressure changes is... further, it won't corrode their tools. But many teams just use air compressors anyway.
Poseur
The silly part of the entire Nitrogen fill issue is HOW does anyone fill a new tire completely with 100% nitrogen? Think about it.
When a tire is first mounted on a rim, they do this in ambient AIR, roughly 78% nitrogen, and the balance is all that other stuff. Once the bead is set, do they then VACUUM out the air in the tire and replace it entirely with 100% nitrogen? Of course they don't. Unless they have their tire mounting machines in a completely sealed off enclosure with 100% nitrogen in it they are never delivering on their promise.
It's a sucker's game. In the aerospace business we are seeking 100% nitrogen so that in the ultra cold environment of high altitudes and/or space no moisture is captured inside a tire that can freeze up and cause issues later. Nitrogen provides a more stable pressure. Trust me, when an aircraft tire is mounted and filled with nitrogen, it's done a lot differently than any passenger car wheel and tire.
