PASM FAILURE YET AGAIN ON 08 C4
Old Jul 26, 2011 | 10:21 AM
Thegman's Avatar
Thegman
Question PASM FAILURE YET AGAIN ON 08 C4
Since the day I took delivery of my C4 I have had issues with the PASM. The dealer told me the battery must be fully charged or the PASM will shut down??? Never the less, for the 3rd or fourth time since then the little beep happened, the "PASM Failure" illuminated and now the PASM won't come on when I put on the Sport Exhaust. Trip number 4 to the dealer.......
Anybody got any ideas? It's a low miles car that sits on the tender regularly.
Old Jul 26, 2011 | 04:32 PM
zoomzoommo's Avatar
zoomzoommo
Probably obvious, but perhaps ask the dealer to replace the battery and see if that corrects the problem?
Old Jul 26, 2011 | 07:54 PM
jhbrennan's Avatar
jhbrennan
You're talking about PASM and not PSM correct? Don't accept such a BS answer. It's true if you disconnect the battery you'll get a PSM error (not PASM) and that error goes away as soon as you reconnect the battery and turn the steering wheel. This info is in the owners manual.
Old Jul 26, 2011 | 10:07 PM
gota911's Avatar
gota911
Newbies Hospitality Director
If a low battery charge is really causing your PASM issue (I have never heard that one before) have your dealer test the wire harness between the alternator and the battery. Also have them test the battery cables. Some 997.1 cars had a bad batch of alternator wires and/or battery cables which kept the battery from getting fully charged.
Please post back on what they find.
Old Jul 27, 2011 | 03:52 PM
aka_Sven's Avatar
aka_Sven
After changing my battery I started getting PASM failure messages every time I drove my '07 C2S. The dealer replaced a position sensor in the steering column (under CPO) and that fixed the problem.
Old Jul 27, 2011 | 04:13 PM
CBejbl's Avatar
CBejbl
I had PASM Failure with my '09 C2S just a few weeks ago. Don't think it had anything to do with a weak battery, as the car is driven regularly (unless alternater is also not working).
Porsche shop sent off for a "new PASM unit" and installed it. 2 weeks later, still working.
Old Jul 27, 2011 | 04:22 PM
jhbrennan's Avatar
jhbrennan
Position sensor sounds like PSM not PASM. Did you get both a warning light and a failure message or just the failure message?
Old Jul 27, 2011 | 06:13 PM
Bob (CT)'s Avatar
Bob (CT)
Try a different Porsche dealer
Old Jul 27, 2011 | 07:45 PM
aka_Sven's Avatar
aka_Sven
jhbrennan: Actually, I got failure messages for both PSM and PASM, one immediately after the other.
Old Jul 27, 2011 | 07:59 PM
jhbrennan's Avatar
jhbrennan
OK - initially caused by disconnecting battery - happens to everyone. Hook up battery and turn the sterring wheel and it goes away...unless position sensor is bad. Good that it works now but it was most likely PSM that failed, not PASM.
