Calling Targa owners.
Old Dec 30, 2019 | 02:07 PM
must58gt's Avatar
must58gt
Looked at different features/options and decided the Targa fit the bill for me. Porsche don't build many so I looked in Canada also and finally bought the car from a Porsche dealer near Toronto. Really like the large(r) sunroof and hatch for easier access to the rear interior. The sunroof adds some weight so it's less likely to have been raced.
My only complaint is that the sunroof has a leak that neither I nor the local can find/fix. Four visits to the dealer and after considerable expense, I woke up this weekend after an overnight shower and the rear passenger side floorboard is soaked. Ugh. I like the Targa well enough to keep it a long time but not if I can only drive it on a sunny day.
All this to say, if/when you find one you like, suggest take it to a car wash and hose it down with a high pressure sprayer. Then check the interior for any indication of a leak. Might be worthwhile to ask the dealer to pull maintenance records to look for any indication of a sunroof leak repair.
Old Dec 30, 2019 | 03:07 PM
box's Avatar
box
The Targas made with a huge, panoramic sunroof were leaky. When they figured out the 'magic trick'; i.e., a modern, electric roof Targa that looks like a classic Targa, they pretty much fixed the leaking issues.
That said, even modern Targas will leak eventually, but that is typically a drizzle down the inside of the window when driving in a heavy downpour--not the rear floor soaking you've got.
Old Dec 30, 2019 | 04:09 PM
F308gt4's Avatar
F308gt4
You are wrong about that. Properly maintained, they will not leak, and were never considered leaky. My 2009 (bought about 4 years ago) was a daily driver for the first 3 years I had it with no issues. You would hear about it if it was an issue, as there are plenty of targa owners on this site.
Old Dec 30, 2019 | 07:22 PM
Steph1's Avatar
Steph1
Mine never leaked. You can buy the best grease (or should I say greaseless lube, as it is not tacky/sticky) IMHO called shin etsu at a Honda dealer.
​​​​​​Use it to lube the rubber seal all around the roof and your roof shouldn't leak anymore. But also check your drain tubes.
Old Dec 30, 2019 | 08:15 PM
TheTorch's Avatar
TheTorch
or Gummi Pflege Stift
