Fan stayed on after I turned off car?
Coming home today temp. around 90, stop and go traffic for about a 1 1/2 hours. Went back into the garage about 20 min later i noticed the fans were still running. I restated the car and put the spoiler up and turned off the car. One min later the fan was off. Is this normal?
Normal. In similar conditions, mine will start blowing about 5 minutes after I turn the car off and will blow for about 6 minutes. It gets very hot in Austin in the summer, and sometimes the fan will cycle on and off twice after a 45 minute drive. At a Cars and Coffee event this past weekend, a 2010 Targa parked next to mine, and his fan came on about 30 minutes after he turned it off and ran for 3-4 minutes.
Thanks for the responses...
My does and when i turn the key back to ignition on/stand by (position 1) the fan will turn back on.
Shouldn't the fan keeps blowing even with key out if it is needed?
After an extended drive in 90 degree weather, I usually open the lid on the engine compartment to alow the heat out faster. The fan is usually running but will turn off in a minute or two.. Steve in Saratoga Springs, NY
If you want to help your car cool down, do like I did for a while: buy an electric fan and position it at the front of the car and after you pull the car in to the garage turn the fan on low and have it blow air at the front of the car though aim the fan a bit lower to really force air *under* the car. This mimics a bit the air flow the car experiences when moving and while it won't be as effective because of course the engine is not running and the coolant is not circulating it does help remove heat from the engine compartment. If you leave the garage door open a crack it helps keep the garage temperature down from a hot car being parking in it.
After a half an hour or so you can turn off the fan and you'll find the car is rather cool, cooler than it would be without the fan blowing. Also, don't forget to close the garage door all the way.
Sincerely,
Macster.
You probably should leave the engine compartment cover closed. If you open it the fan does not blow air into the engine compartment as effectively as it would with the cover closed so the components in the engine compartment are subjected to longer heat soak periods at higher temps than they would otherwise be.
Sincerely,
Macster.
Sincerely,
Macster.
Poseur
I used to position a large box fan on the lip of the engine bay of my 911 when they were air-cooled--and pulled the air out of the engine area. I think it helped keep the heat damage to a minimum over the years. Although Porsche considers things like heat when they chose materials for the engine area, I think it will extend the life of many aux. components by drawing the heat away.
