Sport setting question
Does the 07 C4S with the Sport button (PASM) cause the car to lower 10mm at speed ?
I thought I had read that in the manual or online.
No. The air suspension (optional) in the Cayenne and Panamera does exactly that - but PASM doesn't.
Standard PASM has two settings, regular and sport. Sport stiffens things up - but doesn't lower them.
Sport PASM (aka SPASM) works exactly the same way. The difference is that SPASM's regular setting is stiffer than PASM's regular and ditto for the sport settings. PASM is one cm lower than the normal (non-PASM) suspension, and SPASM is one cm lower than PASM.
Recapping:
PASM is one cm lower and a bit stiffer than standard suspension;
SPASM is one cm lower and a bit stiffer than PASM.
DMoore
'11 GTS (with SPASM)
'10 P4S (with air suspension)
Recapping:
DMoore
I also use it on speed bumps/lumps/humps and various other places where terrain puts the bottom of the car at risk. Things like fording creeks and so on.
It is the rational that a "stiffer" suspension, while driving over speed bumps/humps/ etc.. would cause less "rebound hence mitigate possibility of bottom dragging/touching the speed bump/etc..?
I still don;t see how it helps with entering/exiting of driveways. I have a step driveway entry and MUST enter/exit at an angle, SLOWLY, to avoid scraping the chin spoiler.
Not rebound, but preventing the nose from diving as much.
Here's how it has worked for me: There are two spots in my daily commute where my front lip will scrape unless I go really really slow. One is where a downsloping road meets a flat cross road - similar to a driveway meeting the street. With sport mode on, I can navigate this at 5 mph rather than having to stop and creep at 1 mph. Sport mode prevents the front end from dipping much if at all and hitting the front lip.
The other spot is exiting a driveway from a parking garage. Again, without sport mode on I scrape unless I go 1-2 mph because the front end dips when the front wheels hit the joint between the driveway and the street. With sport mode on, it doesn't. Hope that helps.
one more question:
-Stock suspension- no button
-PASM is one cm lower and a bit stiffer than standard suspension; there's a button under the radio that says "sport"
-SPASM is one cm lower and a bit stiffer than PASM. it has a button under the radio but what does it say?
one more question:
To add to the complications - if PASM/SPASM and PDK with Sport Chrono Plus there are 3 button, sport, sport plus and the shock absorber. Push either sport or sport plus - the trans changes programs, throttle response changes, AND the shock absorber button lights up because it's now also in the sport setting for the suspension. But you can activate the sport suspension setting without affecting engine/PDK by pushing just the shock absorber button; or you can activate sport or sport plus for engine/PDK but then DEactivate sport suspension setting by pushing the shock absorber button. The light will then go out on that button.
(I've had all 3 suspensions. '08 C2 was std; '09 C2S had PASM; '11 GTS has SPASM. The C2 was a 6-speed; the C2S and GTS are PDK with Sport Chrono.)
Sorry to be so long winded!
DMoore
'10 Panamera 4S
'11 GTS
So:
-PASM is one cm lower and a bit stiffer than standard suspension; there's a button under the radio that shows a little shock absorber
-SPASM is one cm lower and a bit stiffer than PASM. it has a button under the radio that shows a little shock absorber.
Right? i was just wondering if you can tell if a car has PASM or SPASM by the buttons?
So:
PASM is stiffer and 1 cm lower
SPASM is even stiffer and lower than PASM
From the interior you can't tell the difference between PASM and SPASM. The difference is the relative stiffness and ride height.
DMoore
'11 GTS
'10 P4S
991, 997, activating, aprotseting, chrono, difference, front, lip, module, panamera, pasm, porsche, radio, settings, sport, sports, suspension
