Thinking of swapping my C2S rear lid with the new C4S...w/the red reflective strip
Is it a straight swap that I may "reuse" my wing and latch and any other "things" attached to the rear lid.
The 2 parts: rear C4S lid and red reflect strip is $960 CDN. Plus paint (I can do the install myself).
Anyone perform this change?
Good timing
i just received the Reflector part from Suncoast today. i also bought a used decklid for parts needed. Suncoast said they are same size but never tried. I wiil be their Guinea pig. hope to have it painted and installed in next 10 days.
my Targa is an 08, 997.1.
new part from 997.2
new part from 997.2
Poseur
This should be a simple switch over. I don't believe for a second that Porsche would add another variable here--a slightly different size for the rear decklid on a wide body over a narrow body. From a manufacturing and engineering perspective, it would be foolish.
BTW, I saw a 997.2 one day at our local dealership that was a Carrera 4--but it LACKED the red reflective piece. It was a factory error. So, logically, if the Carrera 4 (997.2) accommodated a regular lid, then it follows that a reflective decklid will fit your regular narrow body.
I have seen a ton of 4's without the red reflector. Especially here in so cal. I personally do not like the reflector. Its a factory option to order it without the reflector.
Nevertheless, I love the reflector for the fact that it give the 997 a truly ol-skool look to the air-cooled Carreras. Plus it provides the visual effect of the "rear-end" being wider
Cheers!
