View Poll Results: did YOUR car suffer an IMS failure
yes, the IMS failed
5.66%
No issues with IMS
94.34%
Voters: 1661. You may not vote on this poll
IMS failure for your 997 car, Y or N? tell us (yr, 997.1, .2, m96, m97, failure mode)
Old 11-26-2013, 10:43 PM
  #406
Carrera997re
Carrera997re's Avatar
Thanks rich what numbers indicate your safe from explosion
Old 12-07-2013, 08:23 AM
  #407
mlv_250
mlv_250's Avatar
Model Designation CARRERA COUP
Model 997-1
Year 2007
Order Type 997110
Engine code M96.05
Mileage 53K
IMSB Failure No
Old 12-07-2013, 11:19 AM
  #408
FullThrottle64
FullThrottle64's Avatar
'08 997.1 C2S. No problems yet, 16K miles and counting.
Old 12-08-2013, 10:52 AM
  #409
spittingcobra
spittingcobra's Avatar
05 997.1.C2S. At 48,000 replaced clutch. Original IMS was fine but got the retrofit anyways.
Old 12-12-2013, 12:36 PM
  #410
Loud223
Loud223's Avatar
I just bought an 05 C2S with 45,000 miles with the understanding that S's didn't have the IMSB problem. Date of build was 04/05, vin # indicates it is not a class vehicle according to class action website. The engine # indicates it has the larger sealed bearing. Depending on how you look at the bearing issue, smaller replaceable larger non replaceable, I lucked out.
This is a great forum and a great thread.
Thanks for all the info.
Old 12-12-2013, 06:54 PM
  #411
FullThrottle64
Is this correct? I wasn't aware of this - any way to verify?
Old 12-12-2013, 07:26 PM
  #412
Loud223
Loud223's Avatar
Sorry FullThrottle64, I was inferring that I was mistaken in my belief that S's didn't have the IMSB problem. Which is why I bought an S. After reading every post in this thread I realized after purchase that it depends on date of manufacture as to which Bearing you have.
Old 12-12-2013, 07:35 PM
  #413
myw
myw's Avatar
exactly.
after feb/mar 2005 you should have the bigger (stronger) bearing. they are all still prone to failures, but the late 2005+ -> 2008 and onwards have had significantly less.
to be sure check your vin number as well as manufacture date on your porsche official certificate of ownership and then cross reference the ims settlement website.
Old 12-14-2013, 12:00 AM
  #414
russm535il
russm535il's Avatar
2006 Carrera coupe 26k miles no problems uses no oil in between oil changes
Russ DeJulio Pittsburgh PA
Old 12-15-2013, 07:25 PM
  #415
Charley250
Charley250's Avatar
Where you can see on your engine if you have the little or the bigger bearing?
Where you can see the VIN of your engine? Do you need to lift the car?
Old 12-15-2013, 07:40 PM
  #416
jasper
jasper's Avatar
Unfortunately the only way to be sure is to remove the transmission but if its 2006 or later its almost certainly a big nut.
Old 12-15-2013, 10:33 PM
  #417
Charley250
Charley250's Avatar
I found my engine number
I have a 997.1
C2 2005
Avril 2005
Big Bearing
53K Miles
No issue
Old 12-19-2013, 03:34 AM
  #418
E63
7th Gear
E63's Avatar
2006 C4 daily driver/commuter here with no issues...
119,500 miles and still running strong
Old 12-19-2013, 12:52 PM
  #419
Ynot
Ynot's Avatar
Good to hear, you win in mileage, I haven't seen anyone with more miles.
Old 12-20-2013, 11:38 PM
  #420
Captsteve123
Captsteve123's Avatar
Default IMS Failure Imformation
Best bet is to go to this link and type your VIN number and it will tell you if your vehicle is part of the class.
http://www.imsporschesettlement.com/porsche-vin/
Quick Reply: IMS failure for your 997 car, Y or N? tell us (yr, 997.1, .2, m96, m97, failure mode)
