X-51 intake and headers installed :)
I probably have about 8 hrs in doing the full exhaust and intake.
Headers by themselves could be done in a little over an hour if you don't have rusty hardware.
Intake takes a little futsing and fiddling with to adapt to a stock S motor, and of course you need to be very careful with the layout for the hole in the engine lid. Would be a major bummer to mess that up.
Headers about $900.
I was able to do a little better than that finding an air box that a shop had been sitting on for awhile.
Phil
Hey, no problem! You're welcome.
Let the mods begin!
Phil
Phil that airbox looks lovely man!
So when you talk about cutting you actually mean cutting the steel/aluminum engine cover? Yikes. How did you do this, tools, template?
Yes, I cut the second hole in the engine lid for the second cold air intake. The lid is reinforced plastic of some sort, not metal. I used a dremel tool to make the cut and grind to fit.
There was no template. I had figure out placement and size of the cut-out on my own. Not too difficult, but a bit nerve ratcheting.
Thanks for stopping by!
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Phil
