Another Centerlock Question
New guy here. Currently driving an M3, but I'm considering purchase of a GTS. I think I've read all the posts concerning the centerlock wheels. For those of you who have replaced tires, have you found tire shops (other than a Porsche dealer) that can/will do the tire mount and balance? I appreciate the precautions with removing and reinstalling the wheels on the car, but if I can get them off, are there any special tools or fittings required for the mounting & balancing?
Bob
Bob
Just make sure they have the tool to spin on the hub, so when removing your wheels, they don't bump your rotors or calipers. I bought one to use at home, and would just take it for a non-Porsche tire dealer/installer to have when working on your car.
Bob
Bob
The tire shop I've used for 20 years doesn't have a big enough torque wrench or torque multiplier to install the CL nuts. They said they'd swap my tires if I bring in the tools for them! I just wasn't comfortable with their unfamiliarity with the concept so I took the car an independent Porsche turner/race shop locally and had the work done there. It cost an extra $100 but worth it for peace of mind. I need to buy the Porsche breaker bar (Suncoast Parts) to carry in the car for emergencies.
Removing/installing is the only issue with the CLs. Tire installation and balancing is the same as any other wide, low profile tire.
DMoore
'11 GTS
'10 Panamera 4S
You can buy a 4' long torque wrench from Tooltopia.com for about $300. Still surprising that your tire dealer does not have one. It is the same type torque wrench as you would use to remove and install lug nuts on an industrial truck.
Will the wrench fit in the boot...and does it weigh more than the CL weight reduction?
