Broken bolt off CAT. converter. Need help
Old 04-10-2011 | 01:16 PM
JohnAMG's Avatar
JohnAMG
Default Broken bolt off CAT. converter. Need help
I was trying to remove the center muffler by removing the the nuts that are secure to the flange off the cat. converter. Well, one of the bolt on the right converter broke off. Now, what should I do at this point? Can I remove the broke bolt off the cat. flange? Any suggestion will be greatly appreciated.
John
Old 04-10-2011 | 01:33 PM
vinnysca's Avatar
vinnysca
You might need to cut the bolt off with a steel cutting blade on a dremmel tool. Did you soak the bolts with a penetrating oil overnight before attempting to removing them? I guess it's too late for that now. Cutting off the bolt and ordering a replacement bolt might be your only solution I'm afraid.
Goodluck.
Vinny
Old 04-10-2011 | 01:55 PM
JohnAMG's Avatar
JohnAMG
I was able to remove the broken bolt. Thank goodness the bolt is pressed fit and I was able to "Moderately" tapped the bolt out. Off to Homedepot I go to find a non-rusting bolt/nut combo.
John
Old 04-10-2011 | 02:39 PM
okbarnett's Avatar
okbarnett
you need to go to porsche see if you can get that origional bolt. you need to replace it the same as it was. or if you wont do that, go to napa or a nut and bolt store and get a grade 8 or 10 bolt
Old 04-10-2011 | 03:21 PM
JohnAMG's Avatar
JohnAMG
According to the Porsche catalog CD, I couldn't locate a separate bolt for the catalytic converter flange. I did see a bolt with part number for the Cayman. Homedepot bolt is only for temporary use only until I locate the OEM part.
John
Old 04-10-2011 | 05:24 PM
Macster's Avatar
Macster
John
Might have to buy the bolts in sets of 2 or 3 or how ever many there are.
Which may not be that bad of an idea. If one's in sad shape -- sad enough to break -- the others might be to and while you're there replace them all. The ones that are original won't get any better over time.
Sincerely,
Macster.
Old 04-10-2011 | 05:42 PM
okbarnett's Avatar
okbarnett
I think that if you go to porsche they will have the seperate bolt
not everything is on those parts cd
Old 04-10-2011 | 05:43 PM
Skibum's Avatar
Skibum
It's a standard metric press fit.
Should be able to get it at a good hardware store if not a regular auto store.
I'm not sure a Porsche branded flange bolt is called for...
Old 04-10-2011 | 05:48 PM
Edgy01's Avatar
Edgy01
Poseur
Put some AntiSeize on it when you reassemble it.
Old 04-10-2011 | 06:49 PM
JohnAMG's Avatar
JohnAMG
Thanks for the reply guys. I will call suncoast tomorrow to locate the bolts. I broke the second bolt 1 hour ago and it took a while to get the broken part out. These OEM bolts are useless! I am almost afraid to touch other bolts
John
Old 04-10-2011 | 06:52 PM
Skibum's Avatar
Skibum
Did you use penetrating oil and let it sit for at least overnight?
(I like to do a heat cycle, then spray again and wait an additional 12 hours)
Old 04-10-2011 | 07:01 PM
JohnAMG's Avatar
JohnAMG
I used wd40 and let sit for about 6 hours. Is there something else I can try?
John
Old 04-10-2011 | 07:17 PM
Skibum's Avatar
Skibum
I think a bit more time and a heat cycle would help.
NOTE: My only experience comes from the flange I took apart on Friday.
Old 04-10-2011 | 08:27 PM
JohnAMG's Avatar
JohnAMG
What do you mean by heat cycle?
Old 04-10-2011 | 08:29 PM
Skibum's Avatar
Skibum
Could be smoke and mirrors..
I spray, let soak in.. then start the car, let the stuff heat up.
Then after it cools I spray again and let sit overnight.
All my bolts came out pretty easily.
