DIY - Refurbishing Door sill/scuff plate
#91
easy search in 991 section:
https://rennlist.com/forums/991/1050...t-pop-off.html
And, this link lead to this one by Porsche-nuts that shows it quite well. "here are instructions
http://www.macarbon.com/install_guid...stallation.pdf"
All still leaves my question re. "PET" unanswered. What does that acronym mean?
#94
I just did this repair. It is only "satisfactory"
as the OE covering is difficult to feather-edge. Also, the ACE flat black laquer is more reflective than the OE finish. But, it will do for now. (See attached.)
BTW, a friend who is a Concours pro covers his sill pieces with Gaffer's tape. And, removes it when he shows the car. The advantage to Gaffer's tape is that it doesn't leave residue as Duct tape would. Although it is more expensive than Duct tape.
#95
Looks Good and Suggestion
I just did this [door sill] repair. ....
#96
Another option over paint is a wrap. I used flat black 1080 from 3M. Is super easy since the entire trim piece comes off and the center buttons can be removed. Making the wrap an easy effort. Plus it is super easy to remove and replace for cheap as needed. Since I like the look I'll most likely pull this wrap off soon, sand the trim piece to flat (I did not do that this time, just put the wrap over the scratches which in turn allowed a couple small scrapes to be visible but still 99% better than before the wrap) and reapply.
I too have a friend that is a Porsche conours judge who travels the country to judge events and also shows his Porsches. We spoke about how he repaints his every couple events and then I showed him the wrap and he was impressed. He took some extra I had laying around and was going to try the wrap for the next event he was showing his car in. When done right you'll never know it was wrapped.
#98
What's the trick to getting the buttons out of the sill once off the car. Looks simple enough with the clips but it's not coming out easily and don't want to break.
Or are you guys just tapping over the buttons when spraying?
EDIT: I got in 30 seconds after I posted. Doing both clips on each side at once did it.
#100
Not in MA anymore
Not in MA anymore
YMMV
Matt
Ironman88 (05-15-2020)
#102
Thanks Matt, was afraid I would have to remove the console. The wrap looks fantastic. As I have zero experience with it I'll likely go with some paint and if I don't like it just buy a new useless piece.
#104
The door sills in the before shots were clean and had been treated with a vinyl conditioner. Problem was the embedded scuffing that I (previous to using the Magic Eraser) could not remove.
Your recommendation Matt really worked. Thanks.
Driver's side before...
Driver's side - before...
Driver's side - after...
The following 2 users liked this post by Ironman88:
ilovemaui (05-15-2020),
Matt(inMA) (05-16-2020)
#105
Pretty close with Rust-Oleum universal flat.
The center of the buttons painted but the buttons themselves are not. That's probably the best contrast to see the different shade. I think after installed and some armoral over all of it, will be about perfect.
mtv3906 (02-27-2023)
