Airbag light on after drver airbag removal and refit
2005 Porsche 911 Carrera S with Chrono pack.
I removed the steering wheel. After refitting and reconnecting the driver airbag, the airbag warning light stays on all the time for a few days now. Is this normal and something have to be reset in the computer, or do I have a fault. I had another car marque that I have fiddled with, which had to have the computer reset after airbag removal.
Thanks, Allan
Thanks, Allan
Sounds like a sensor fault.
I hope he did too - last thing I'd want to be working around is an airbag with the battery still connected...and disconnecting will eliminate any fault lights assuming everything was reconnected correctly.
Yes I disconnected the battery before unclipping the airbag electrical connector from the steering column.
So my question is, does disconnecting and re connecting the driver airbag in a 997 trigger the airbag light to stay on, and does this need to be reset in the computer? If not, then I have a fault.
airbag
i have done this procedure on 3 diff P cars. the airbag light always stayed ON. went back to dealer, took him 5 mins to reset.
