Heel and Toe
Heel and Toe
All,
A question regarding heel and toe in 997.
I find it difficult to heel and toe in 997. The gas pedal position does not seem to be optimal for my feet, I guess. I would prefer to have gas pedal face higher, such that its height would be closer to the height of brake pedal.
Any similar experience, remedies to that?
I also noticed that SRP gas pedal has a “winglet”, if you will, on brake pedal side to ease heel and toe process. I just don’t believe that’s what I would need, no firsthand experience however. It’s not the width of the pedal(s) it’s vertical location of the pedals’ surfaces that would make the difference in my opinion.
Comments welcome.
L
Comments welcome.
L
Search please, there are lots of threads on this already.
The short answer is that you aren't braking hard enough, that's why the gas pedal feels too high. The pedals are actually perfect for real heel & toe on the track, in which case your brake pedal should be on the floor because you are braking so hard. No aftermarket pedal mod is needed.
This is a common topic of discussion here on Rennlist.
Porsche designs their pedal placement to facilitate heel-toe on the track and this design means that it can be more of a challenge to heel-toe on the street because you aren't applying the brakes with the same authority that you would at speed. When you're really braking the pedals are lined up as you're expecting.
You're correct that pedal extensions don't really address this issue. It's more a matter of technique than pedal positioning. Most find that once they've "got it" in the Porsche that it becomes easy to heel-toe on the track and on the street, but it's definitely a bit trickier to sort out the nuance at street speeds.
I heel toe mine all the time at all speeds on the street.... ive never even thought of the pedal heights.
I think its just technique.
It more a toe, and foot roll... no heel at all really.
There are some videos of this floating around somewhere
search first. it was really answered before.
practice braking with your foot ball, not with whole foot on a brake pedal, heel a bit up off carpet, then when brakes are fully depressed down (not common for street driving) - rotate foot counter clockwise so heel should reach gas. if you have knee problem or whatever other reason does not make it easy for you - put on rennline extension plate on your gas pedal, it will simplify all this greatly.
http://www.rennline.com/Rennline-Gas...oductinfo/P71/
Leave the heel well out of it, depress the brake with half the ball of your foot and roll the other half onto the throttle in a tidy blip. Works at any speed in any environment. And definitely a big part of the pleasure of driving these things (for us manual tranny luddites).
And remember: Practice makes perfect.
Are you kidding! Porsche is THE BEST car I've ever had in terms of pedal placement for heel/toe.
Mind you that you need to do it while braking harder to get the brake pedal closer to the gas, and then ROLL the foot, I don't really use the heel much.
PS. Only safe place to practice on the street, is to enter a highway exit at full speed (if not traffic) and do not slow down until late in the turn, brake hard and downshift while heel/toeing, you will find it's fairly easy to do!
... of course this doesnt have the same snappy ring to it as heel-toe :-)
Got it!
Thank you all for the input. I didn’t realize that this subject could be such polarizing.
I went today and experimented a bit with my heel and toe technique. My observations are as follows:
Just before you start braking lift your right foot off the floor and position on brake pedal such that your toes are above the outline of the brake pedal.
Your foot will be lifted off the floor - very important.
Now if you rotate your foot counterclockwise on the brake pedal then your heel will land at the bottom of gas pedal for a good blip of gas as you double declutch.
It can be easily done for normal street driving. Saves your transmission a lot of wear and tear.
This way seems to be easier than rolling your foot from brake pedal to gas pedal which I was used to and often used in my daily driver.
The end note is to maintain constant and steady pressure (as required) on brake pedal without increasing brake force as you blip your gas pedal, that's worth practicing a bit.
Cheers,
L
Cheers,
L
Cheers,
L
Cheers,
L
You bet Alex.
Speaking of the best placement of pedals, try Subaru WRX/STI. The pedals are child easy to H&T. Seriously. Rally heritage. Good Scheisse. Ups... pardon my German.
