Check Engine Light / Vist Workshop message
Agree 100% with Macster. I'm all about solving a good mystery...but when it comes to CELs, get it to the shop immediately and get a proper diagnosis.
Hey folks,
needed to reach out for advice on a check engine light i've been getting on a 2011 997 carrera during hot weather only. On cooler days, car runs fine with no mis-fires and smooth acceleration, but with the warm weather we've been getting, I can drive the car for about 15 minutes until the oil temp needle hits about 220 F. Suddenly, the car idles rough and the check engine light comes on. I then pull over, shut the engine off to let the engine cool down to 150F after which I am able to drive another 5 to 10 minutes and then the same thing happens-- rough idle and check engine light. There is no smoke coming out from the exhaust, but i did notice the passenger side exhaust has a little more "loping" air pressure than normal at idle, the left side exhaust feels normal during idle. Any thoughts on which oxygen sensor (or something else) can causing these symptoms.
rgds,
dave
rgds,
dave
Dave,
You need to get a cheap, inexpensive, iphone type of application with a wireless plug that can tell you what the code is. Then it would be much easier to help you. Right now, you have a choice 1,000 CEL codes that may show up.
I tried to get the error codes using blue driver and it appears the no codes were generated. When the CEL comes on, does a code automatically get generated and kept? After i let the car cool, the CEL goes off. Sounds like i need to catch it with OBD2 connected while driving. I did download a "mode 6" file which looks pretty cryptic. is there fault info buried in this file? I attached it if someone "speaks" that language.
Hey folks,
an update on the over heating induced CEL. Caught the CEL with the ODB scanner and it showed cylinder 5 missfire. I ordered coils and spark plugs and put those in this weekend.
I think case is closed. Just curious why the faults arent stored in the ECU-- I had to catch it when it happened.
thanks
thanks
