18" vs 19" wheels
#31
Cheers
#33
CCW wheels do fit. there is a third alternative now for total custom 18" wheels in 9" front 12" rear - about of $1600 shipped for a set:
http://www.6speedonline.com/forums/9...san-diego.html
but they are cast wheels, not forged like CCW.
#36
Poseur
Not only do the 18s fit the 997S with the larger calipers, but they also clear the PCCBs which are even larger. (See earlier photo of them on my car with the PCCBs). The 18s were always a snow tire option for 997S owners because some of the larger 19s (like my Carrera Sports in 8.5 and 11.5 widths) cannot handle a set of cable chains in the rear--just too close a fitment.
I don't have any idea what utkinpol is referring to--unless it's an aftermarket 18.
One final note on the 18s (Carrera IIIs) is that they are certainly one of the easiest wheels to keep clean, as well as to touch up. Being a painted wheel, there isn't much to refinishing them.
#37
Dan do you know if they will fit a 09 C4 with PCCB?
#38
Poseur
They will fit, but the offset is different. Sometimes that can be made up with the 17mm spacers on the rear. (Front offset is the same). Clearing the PCCBs is not an issue.
Fronts: 997.362.136.00 8x18 ET57
Rears: 997.362.140.01 10x18 ET 58
