Trickle Charging?
Old Jan 23, 2011 | 12:49 PM
SARGEPUG's Avatar
SARGEPUG
Default Trickle Charging?
I have a trickle charger that I would like to use, but the trunk light would be on while I am charging. What is the solution here? How do you disable the trunk light or is their other ways. I know about the lighter plug in, I might need to get it.
Old Jan 23, 2011 | 12:53 PM
At Law's Avatar
At Law
I highly recommend your purchase a Porsche (or the equivalent--Sears sells a Die Hard maintainer for approx. $25.00) battery maintainer, which plugs into your lighter.
This is the safest way to maintain the battery while sitting for extended periods.
Old Jan 23, 2011 | 01:01 PM
Coochas's Avatar
Coochas
I have a CTEK on my 997 battery. I attach directly to the battery and leave the battery cover in the front trunk space. The cable from the battery can then be routed between the back of the hood and the windshield: there is plenty of room to then close the front hood without crimping any cables.
Old Jan 23, 2011 | 01:12 PM
Leader's Avatar
Leader
I have a CTEK with the cig lighter cord, which I plug into the passenger's footwell socket, routing the cord under the passenger's door. It closes fine...very handy, and no need to mess with the frunk.
Old Jan 23, 2011 | 01:13 PM
morecarl's Avatar
morecarl
I charge from the front and my trunk light turns off after a while on its own.
Old Jan 23, 2011 | 01:32 PM
SARGEPUG's Avatar
SARGEPUG
Thanks guys and this is also very interesting from morecarl! That being the case, why would I need the lighter unit, if I already have a convetional one.
BTW is this the lighter one
http://cgi.ebay.com/ebaymotors/NEW-B...Q5fAccessories
Old Jan 23, 2011 | 01:41 PM
MG's Fast Fish's Avatar
MG's Fast Fish
I have Porsche's charger (CTEK) and this is my 2nd winter of doing this......
I went to Autozone and bought a roll of rubber door gasket. I crack the driver's window down as miniumum as possible. I have the charger plugged in the center console. The cord runs out to the corner of the driver's window (upper right). I use the the door gasket to fill in the void between the window and the frame.
The cover's on the car. I don't like closing the cord on the door. Seems to be doing ok--no problems.
Old Jan 23, 2011 | 02:15 PM
Alstoy's Avatar
Alstoy
Do other brands have this issue? If not-why?
Old Jan 23, 2011 | 03:59 PM
docfink's Avatar
docfink
I have the CTEK too with the cigarette lighter connection. I just shut the door--no problems with the cords, and no lights on.
Old Jan 23, 2011 | 04:02 PM
vexed's Avatar
vexed
I use a Battery Tender Plus and connect to the battery. I agree the light goes off after a while since you can close the hood but not latch it. The Battery Tender can be had for much less than the one you are looking at and you can buy a lighter adapter for it if you prefer to charge through the lighter.
http://www.amazon.com/gp/product/B00...4SG2V06XD1T47F
Old Jan 23, 2011 | 04:10 PM
jhbrennan's Avatar
jhbrennan
I believe there is a notch in the rubber seal at the bottom of the passenger to accomodate the cord.
Old Jan 23, 2011 | 04:38 PM
At Law's Avatar
At Law
Where is the notch? I looked and looked and couldn't find it.
It was my understanding that the 996's have the notch and the 997's do not.
Irregardless, I have had no issues just slamming the tiny wire through the door.
Old Jan 23, 2011 | 04:48 PM
Leader's Avatar
Leader
Closing the door on the wire will not hurt either the door or the wire.
Old Jan 23, 2011 | 04:56 PM
morecarl's Avatar
morecarl
Lightbulb
Forgot to mention that I am using a battery tender with mine.
Old Jan 23, 2011 | 06:50 PM
dsanto's Avatar
dsanto
I have both the c-tek and battery tender and can close the frunk and still move the cord. I have the cord come out the bottom front side and it works great. I've been doing this for years on all my cars and have always been able to close the trunk or hood without pinching the cord.
