New H&R Springs Installed
I finally got my H&R springs installed by my shop in Tampa. All I can say is "Wow!" I wasn't really sure if I would like them but after the drive home last night it feels much better. The H&Rs seem to control the struts better then the stock springs. I did one DE with the suspension completely stock and it did have a little more roll then I would like and some lag on steadying the car in corner changes. I think that these springs should solve that little issue. The car is a little lower so if anyone is worried that the car will be dragging the ground, no worries.
All photos off of my droid phone:
Before:
After:
Before:
After:
Mine settled too low..
It's all personal taste, but after a few weeks my H&R's that I had installed on my 06 997 settled quite a bit to the point that they are too low for me (defined as 25.5" from road to wheel fender).
I also am unhappy with the handling, all to the point that I am considering either Bilstein HD or Sports Shocks all round with ROW Springs.
All subjective I suppose, but the H&R Springs alone on stock suspension is not my cup of tea.
The KW Variant 3 has individually adjustable compression and rebound, vs the PSS9 which is a dual purpose single ****.
If it is a daily driver with occasional track use I would stay close to the Bilstein and KW units. KW unit might require more attention as you adjust compression and rebound dampening separately, as the Bilstein is not as complicated with a single **** adjustment.
PM me if you want more details for your specific application- I speak in more generalities in this post.
