Recommend Houston TX Porsche mechanic for PPI?
I live in Missouri but am considering purchasing an 09 911 from a Porsche dealer in Houston that has been driven less than 7k miles, one owner, and a clean CarFax (for what thats worth). I would fly to Houston to see it and most likely have the car shipped if I proceed with the purchase. Can you recommend an expert mechanic for an independent pre-purchase inspection? Rough idea as to how much time to allow and the approximate cost?
http://www.6speedonline.com/forums/9...o-houston.html
Good luck!
BTW I think the generic PPI is very over-rated. Do not just trust a recommended mechanic, far too many of them use the PPI as a way to make some money for no work. I recommend asking for this exact information :
1. DME readout - have them send you an exact copy of what they get, not just their opinion on it
2. Compression test - this is the only way to tell if there's damage inside the engine
3. Check for oil weep on the engine, particularly in the front
4. Check for bent suspension parts, cracked coils, and rust on the exhaust
and of course get CPO whenever possible.
IMO if you're buying from a Porsche dealership, they should give you a DME printout for free. I've never heard of that actually happening but it's pretty absurd for them not to.
Forum newbie here reviving an old thread
I'm actually looking to pick up a 2010 Cayman from a Houston dealer but all the Porsche/Indy dealerships I talk to are scared about doing PPI's and I can't seem to find anyone half decent willing to do more than a "visual inspection." It's so bad in fact, that I was referred by a service advisor at Momentum Porsche to reach out to a guy named Roy Bent. Mr. Bent advised me that his service would cost FIVE HUNDRED dollars and would only consist of a visual inspection. When asked if he would at least check brake pad/rotor thickness and fluid levels, he chuckled as if I was making a joke. I checked into the other names mentioned above as well and this is the current status of the aforementioned shops:
After giving one last call to Porsche of North Houston, I learned that the law recently changed and now places liability of any errors/omissions in a PPI on the inspector thus causing a lot of places to stop selling the service. Given where things are currently at, does anyone in the Houston area have any updated recommendations as to certified Porsche mechanics who might look over my car? I don't care if they call it a PPI or not, just want the car checked out by someone specializing in Porsche's.
- Viking Motorsports - Couldn't find it; found a Viking Automotive specializing in Volvo's though; no certified Porsche mechanics on staff
- Motorwerks - Akram has left and there's no certified Porsche mechanic on-premise any more; Sunil was the guy on the other end who said that a PPI would run $250, be a 50-point inspection, and was the closest I came to anyone recording any actual measurements
- Drivers Source - Don't do PPI's anymore
- Pro Technik - Number is no longer in service; I'm assuming they shut down
I was gonna suggest the same thing. I had mine done by them about a year and a half back. IIRC, cost was in the $300-$3350 range and they were pretty thorough.
Edit: You can also give Tony at Today's European Cars a call. He's the owner and I've used him for my two previous BMW 5's. I would trust him with any car I owned, but he doesn't have the dealer software for the newer Porsches. However, if you ask him, he will tell you what he can and can't do and won't waste your time - this I can guarantee. Very patient and very helpful. I called him for my most recent issue with my car, he offered to read the OBD codes to see if it would help (I know he wouldn't have charged me). But, my car had flashing CEL so I had to take it to a shop I know has the right software. Tony said he doesn't have enough newer Porsche owner clients so can't justify the cost of the software. For anyone in the Houston area PLEASE consider using Tony if at all possible. He is the type of mechanic everybody wishes they had: honest, helpful, do-it-right-the-first-time kind of guy. I didn't say cheap. He's not any more expensive than any other indie I've dealt with and cheaper than the dealer. Sorry for the long commercial... I just want to drum up business for him so I can start using him again. P.S. I will still take my car to him for any mechanical issue that I cannot do myself.
I just picked up my Cayman S this week in Houston and needed a quick inspection/PPI. I only had a day's notice and took the car to European Auto Techniks in north Houston.
I've seen a lot of P cars and the ppi's I've had in the past at the Porsche dealer was pretty much useless. I was looking for two basic items, over rev report and metal particulate in the oil filter.
They were able to fit me in within an appointment and had me in and out. Ran a full computer (autologic) report with all recorded faults and overrev report. I also had them pull the oil filter, cut it open and inspect. All for around $190.
Good luck.
Good luck.
Good luck.
Forum newbie here reviving an old thread :thumbsup
Some shops will provide a visual inspection and perform DME readout but they will not declare an official PPI nor give and opinion on status in Houston. It will be more of, yes or no to buying the car vs listing items of concern or major issue.
My lesson buying long distance, I would always go and see the car in person. I know this add expense but much better than buyer remorse because you found something that an inspection did not find.
car, cost, houston, independent, inspection, mechanic, porsche, ppi, pre, prepurchase, pro, protechnik, purchase, technik, tx
