Any way to change navigation arrow/map behavior?
I have a 2006 C4, and the owner installed the navigation system after they bought the car (not sure if that makes a difference, but thought I'd mention it).
While using it for the first time the other day, I noticed a behavior that drives me crazy. At some of the closer-in zoom levels, the arrow stays stationary always pointing up, and the map rotates around it. I hate that. I want the map to always stay stationary so that up is North, and have the arrow rotate instead - like it does at the lower zoomed-out levels.
I looked in the PCM manual but didn't find a way to change this behavior. Does anybody know if it can be changed, perhaps by the dealer changing a setting somewhere?
On my car, I can touch the arrow to change it - not sure about an '06 though.
The "north up" and "forward up" setting is hidden on those 997.1 PCM systems. It's been a while, but I'm pretty sure you access it by pressing the right-side ****, which pulls up a little context menu with that and a few other settings. I'm going from memory, though, I sold my 997.1 Nav car a year ago.
i have an 06. on mine there's a main setting to have either the arrow facing straight up, or to have north up/south down, etc. BUT even when in arrow-up mode, at a certain point of zoom out (10miles? 20? i forget), it switches to north-up until you zoom back in. additionally, if you you use the cursor feature, i notice it switches to north-up, until you exit that feature.
are you saying you do have the "north-up" setting but it's still going arrow-up upon zoom in? or do you not know about that setting feature?
Thanks for the ideas, everybody - I'll try pressing the right-hand menu **** tonight and see if I get those option settings.
Spiffy - I didn't know about any of those options. I looked through the user manual to see how to modify that behavior, but didn't see anything at all.
OK, get yourself a PCM 2 manual PDF online if you don't have one and turn to page 70 - read to page 71. Takes less than a minute to find the directions once you have the manual.
In short:
Map Menu - press Rotary **** (16). Menu disappears in 3 secs if you do nothing.
North - by selecting North, the map is oriented North.
Note - If North is not selected, the map is oriented in the direction of travel. With a scale of more than 5km, the map is automatically oriented northward.
In short:
I have a 2004 Jeep, and the built-in nav in that car is laughable it's so outdated. It's also DVD based, which I hate.
When I look at the big electronics module they had to put in the frunk for this solution, I honestly wish the owner hadn't had it installed. But, it's there, and I did have need to look something up in it. It worked okay, but I agree, the maps aren't that good and without a touch screen, it's very clunky to use.
I'll probably get a Garmin anyway and just use the PCM for stereo.
