PSE or aftermarket exhausts?
My 06 Carrera S has a stock non PSE setup. I'd like to upgrade and was considering adding PSE but is there some aftermarket setup I should look at. I dont need to set off car alarms ......often. Cheers everyone.
Porsche PSE is very good. $$$. No drone. Another advantage of the PSE, if installed by a dealership, you have a warranty, and have an on/off funtionality.
http://www.suncoastparts.com/product...de=997sexhaust
PSE sounds great with none of the drawbacks (drone, loss of low end torque, etc.) that you can get with some aftermarket exhausts. And, of course, you can switch it off if you want to. Add in the fact that if installed by the dealer it will be warrantied for the remainder of your factory warranty and it seems a clear choice to me. I love the PSE on my car.
Poseur
Porsche worked hard on developing the PSE after they discovered how much 996 owners hated the mundane sound coming from their watered down 911s. The result is a very fine exhaust tone that is better in that you can turn it on or off at will.
Mike, I am not sure if the warranty for the PSE is the remainder of the factory warranty or just 12 months. IIRC, when the PSE was added to my 987S, it was just for 12 months. Either way, it's "piece of mind".
For sound, you can't go wrong... although some do the PSE hack and achieve the same, at a MUCH LOWER COST!
For HP gain however, you gotto look aftermarket.
Warranty on an exhaust system is a non-issue. Properly installed, they are completely reliable and cause no check engine lights. The PSE is generally regarded to have a good sound and is switchable, but is heavy and expensive. PSE, or most aftermarket mufflers, provide little to no increases in power. Spend your money to install proper aftermarket headers, free flow catalytic converters and free flow mufflers. Additional power, and sound will be civilized at moderate rpm's. A multitude of systems are available: AWE, FVD, Cargraphic, Fabspeed, etc.
Basic Sponsor
Hi backerman, I hope your purchase goes smoothly and either one will work as intended. Its just a matter of price, installation time and sound difference. Our setup is $2095 and I can also offer you a member discount on it. All of our products are covered by a lifetime warranty and manufactured from the highest quality mandrel bent stainless steel, so you will never have to worry about your muffler ever breaking. The installation is simple and straight forward, so its less time consuming. Also the sound difference between loud and quiet is much more noticeable and effective with the Fabspeed system. Let me know if you have any questions and goodluck with the purchase.
Thanks,
Valvetronic Mufflers Image: http://www.fabspeed.com/images/996_GT3_44.jpg
996/997 Valvetronic Maxflo Mufflers Video: http://www.youtube.com/watch?v=25yi3Z05Lks
Thanks,
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
From another post.................
PSE Exhaust Hack "GUNDO HACK"
A "GUNDO HACK", is turning a stock 997 muffler into a PSE (Porsche Sport Exhaust).
This is accomplished by welding a 1.5"-2" pipe connecting the 2 pipes of the muffler.
Some would recommend something less than 2" pipe. Mine is 2" and it is pretty loud. Maybe 1.75" is the sweet spot.
It creates a much deeper and louder sound than stock, similar or better than the PSE.
This can be done by any local muffler shop for about $200.
Just remove mufflers, take them to a muffler shop and show them these pictures, and say: "DO THIS!"
Here is a pic:
Here is a pic:
Location: 40 min South from the 'Ring, 45 min East of Spa
Here is a pic:
Here is a pic:
Alex,
Can you PM the member price for an 09 Carrera S when you have time?
