Best procedure for winterization?
Hey all,
I live in Colorado and its almost time for hibernation.
The PCar is going to be put up for the winter soon. What do you guys recommend for a winterization process?
Thanks in advance
Thanks in advance
Good detail, battery charger and an indoor place to park with an indoor car cover. Beyond that, I am curious myself.
heated garage?
what P car do you have?
Full gas tank with stabilizer, oil change, 10 extra pounds in the tires, trickle charger not battery charger - don't need more than 1-1.5 amps to keep the battery full,
if its an older car that won't suffer too much from having the battery disconnected I would disconnect the battery and then be able to leave doors, hood and trunk ajar so that the seals don't get compressed.
This is my list:
Detail (wash, clay and wax) car
Condition leather
Clean and re-seal cab roof
Oil change
Stabil fuel stabillizer
Full tank of non-ethanol gas
Inflate tires to 52 psi
Parking brake off
Block wheels to keep from rolling
Indoor car cover
Battery tender (Porsche or CTEK) plugged into cigarette lighter
Dessicant (silica) in interior and trunk
Seats full forward (springs off tension in manual seats)
Steel wool in exhaust tips
Remove all but theft, fire, vandalism insurance
Rodent repeller (plug in) in garage
Winter washer fluid
Roll car few inches every 2-3 weeks
I hope that helps.
David
Condition leather
Oil change
Parking brake off
Indoor car cover
Winter washer fluid
I hope that helps.
David
This is my list:
Condition leather
Oil change
Parking brake off
Indoor car cover
Winter washer fluid
I hope that helps.
David
Condition leather
Oil change
Parking brake off
Indoor car cover
Winter washer fluid
I hope that helps.
David
put it away with a full tank of fuel and hot. take it for one last long, fun drive and then park it and don't start it until spring. putting it away hot will remove moisture from the engine and exhaust. starting in during the winter will reintroduce moisture. not good. the rest of the advice here has always worked for me.
Moderator
About a week ago there was a long thread on this very subject. I don't remember the OP, but if you try a search on a few key words like "winterize" or "storage" over the last week or two I'm sure you'll find it. I posted info on using StarTron (stabilizer that is formulated to deal with Ethanol) on that thread.
