Radiator debris cleaning ...MY09 C4S
Found out by mistake that applying the business end of a leaf blower to the front side scoops at high power will blow a ton of stuff out throught the center scoop...in the past I always blew into the center scoop to the right and left when drying off my car...got minimal results...but when blowing into the side grilles!...man what a bunch of stuf shot out through the center. This may be old news but I do it with my weekly wash now and always got junk out. See the photo. Not much blowing around in N.E Florida...just the same...it surprised me. Still waiting for a source for easily installed grille screens...some UK companies have'em for 997.1's....not for 997.2's. Can't get the file to upload...had a neat photo. Thanks all!
Using a flexible vacuum hose inserted through the center opening works great too.
Frankly i think this is the biggest oversight on P's part. Dunno what they were thinking that day. Anyhow, my local dealer, Park Place Dallas, has the GT3, mesh type grills. Im waiting to get my bumper repainted so I will have it install then as it requires the removal of the bumper. good luck and happy sucking
I have a US-made Metro Vac 'N' Blo w/the 4HP motor, which I use in my garage to vacuum and blow cars. Using its powerful suction, just using its flexible hose, it's very easy to remove any debris in front of the radiators by feeding the hose horizontally/laterally through the openings in the center section.
Poseur
I move it around the front and sides of the side intakes and out flies a lot of stuff (997.1). I have even (when wheels are off) shot it from the rear, pushing things out the way they came in.
I plan to remove the front bumper every 4-5 years to fully clean out the radiators. With both a radiator and a condenser sitting next to each other it's virtually impossible to keep debris out from between them along the bottom without taking things apart.
I was aiming the leaf blower into the right and left lower bumper openings/scoops and the debris shot out through the center opening/scoop. Haven't inspected them closely but alot was removed as I described. Thought to blow forward through the front wheel well brake vents...I believe they open to the backside of the radiators.
