OT: NSX Tribute video to Aryton Senna - one of the best ever made!
I did not see any shuffling. Senna keeps his hands all the time at 9 and 3. He does see-saw the steering a bit (that's perhaps what you are referring to) and I imagine that he does it because the chassis is unsettled. Being a smooth driver, on a properly set car he would not see-saw the steering like that.
Right hander at around 0:58. He dials in some right lock then grabs at 9-3 and keeps his hands there for the rest of the corner while applying corrections. It's very common to see-saw the wheel at the track. The only real way to know you're on the limit is to exceed it. Then you apply quick steering and throttle corrections to keep the car there. Senna was also famous for hammering the gas pedal as he corrected. Watch the lap again and pay attention to his throttle technique.
GT3 player par excellence
u guys are missing the point.
shuffle steering, pre positioning, whatever, when you are truly gifted you can steer with your *** and be fast.
prince and play guitar with his tongue and be better than 90% of the guitar players (he did it too)
we architects studied FLW, his floor plan topology for generations, do you see another FLW?
bjorn borg did everything wrong in classical tennis. his ***** are too short, land in front of service line. but he started topspin, it spins over ur head.
when you are good, you are good.
there are no rules for these ppl
for mortals, we use theory and generalization as kludge to help us survive. senna as not human.
it's not shuffle steering or see saw.
at .58 he turns in. street car tends to push, he turns the wheel to get to apex. also at that instant watch his throttle, he's blipping it (throttle steer) to get to apex. then he mashes throttle, car goes off line, he corrects it with a much bigger input turning wheel to the right.
To add to your list, not to forget the great McEnroe with his unorthodox tennis totally dominated an era, good luck trying to imitate his style!
OP, I liked the movie, very artistic, well done. Although it would have been much more emotional and appropriate with f1 footage if it's a Senna tribute. The way it is look like a NSX commercial.
no one really did that.
he's go weird but great serve.
useless forehand, weak backhand. but once he's at the net, you are history.
My understanding of shuffle steering is repositioning your hands after you've turned the wheel. I used to steer like this all the time, until I broke the habit and learnt to hold the wheel at the 9-3 spokes. I had better results after the switch. To me it looks like Senna shuffles the wheel at :58 because of the amount of lock he needs in that long right hander. I don't understand what you mean by throttle steering here... seems like he's trying to find the point where he can feed in full power. Once he mashes the pedal, he has to compensate by opening up the steering. Was he blipping to intentionally oversteer?
blipping to oversteer. well not how i would term it. but it is what he was doing. the car pushes. you turn the wheel to the apex. lift throttle car will tuck in toward apex (oversteer), then get on the gas to straighten it out, then repeat (blipping). once he got the apex. he feeds full power and correct str to get to where he wants to go. steering is always contorlled by both str wheel and the throttle.
I always take comfort in the fact that driving was Senna's job and that's why he was as good as he was.
Since we're all Porsche owners, I assume we must be good at something so that we can afford these cars and I'm failrly sure that Senna was lousy at that something we're good at!
