Is there any way to turn off display on Tach for MPG, Tire press. avg speed functions
I would like to only see the miles per hour on the Tach ... is there any way to shut off the functions that show the MPG, Average miles per hr, tire pressure levels, etc.
I tried using the stalk and do not see this as an option, I also searched the Manual but don't see it either ...
My car is a 997.1 without PASM
I just spent 20 minutes in the garage with my car/manual. Pretty sure there is no way to completely shut off those functions. Nugget probably has the best idea.
i think you can slim it down to only show 1 thing, but cant turn off.. mine showed like mpg up top and other stuff below and using stalk could remove one.. why not just leave TPMS up there?
i think this was one of the 1st question i asked after getting my 911. Its almost absurd that we cant turn it off. IMO that info s/b off to the side, maybe even on the PCM screen. I only want "vitals". Thats precious real estate!
Accurate to 2-4 psi. I inflate tires and check manually then use the TPMS display for relative indications - e.g., if I inflate to 34 and 40 and TPMS shows 36 and 42 then I know what to mentally adjust too. So if LF shows 30 and RF shows 36 I know I need to look at LF and add air.
Monitoring the TPMS all the time should be useful though to spot a slow leak and deal with it before it becomes an RA event. Even this is probably unnecessary as the Add Air warning is going to go off if the pressure falls out of range.
