Found a way to secure my spare tire 997.1
It might not be the most elegant. But I've got a 17 inch "Leaner" spare tire and found a tie down point. I used an old dog collar and found a steel piece next to the CD player that had some gaps. I looped the dog collar through the gaps, then through the wheel itself. The tire does not budge and there is little to no pressure on the strap, tire, or steel. I completed my kit with a plastic bag, plug kit, razor, etc. I think it turned out pretty well. There is still some room under the tire and on top for small things. But I rarely use this space anyway.
I decided on this collar method because I was worried about a bungee cord snapping loose and banging the hook against the inside of the hood giving me an dimple it the hood.
Cool! Great job.
I'd like to put a "real" spare in mine, but I have a C4 with the NAV option installed after the car was originally sold, so I'm pretty sure my frunk space isn't big enough.
Even if I could put a 17" spare in there, could I use that on the rear of a C4 if I needed to?
Cool! Great job.
Reminds me, gotta add some wheel chocks to my kit.
Cool! Great job.
Here is a good post, recalled, covering using that 996-362-020-02 in a C4 by Coochas:
http://www.6speedonline.com/forums/9...-tire-c4s.html
Probably better off with collapsible variant of the spare - still a 17, but 2 inches wider, yet 2 inches less diameter than the inflated version. Unfortunately also harder to find a deal on - the 17x3.5 wheels are all over ebay - many including the jack and tools. Beware of 16in and even 15in older spares.
Found this picture. This shows a nut welded to a piece of steel and fastened to the metal under the trunk carpet. There was a threaded rod and a wing nut that goes with this pic if I remember correctly (don't have it). Cut a small hole in carpeting where threaded rod that's thru lug hole in wheel goes into nut. Then tighten wingnut on other end of threaded rod thru lug hole in wheel and you're secure!
Correct. Even though PCCBs have different overall diameters in NA and Turbo models (and front to back) they are ALL too big for any current spare.
