DIY muffler tip install.
hi guys , as stated above i was looking at the agency muffler tip on ebay and was wondering if the install is easy, and if anyone have a diy guide. thanks
heres the link to the muffler
http://cgi.ebay.com/ebaymotors/05-08...#ht_6202wt_935
Looks like a direct bolt-on, so should be a simple DIY. Just loosen the screw on the existing tips to remove, then slip these on and tighten.
Goodness...now there's even faux PSE tips.
wow i really like the black ones , can you let me know hows the install once u put them on? if good ill probaly get myself a black one. also is it bigger than stock?
bolt, california, diy, guide, install, installation, installed, installing, muffler, mufflers, tip, tips
