How to protect instrument cluster from scratches?
I'm looking to protect the clear plastic surfaces in my car from scratches. I did find a helpful post with a link for a protective film for the touchscreen of the PCM.
I cannot find any information on how to protect the clear covers of the dials in the instrument cluster. Does anyone have any ideas of how to protect them?
Looks like I already have a scratch on one of them
I NEVER had to do anything to protect cluster on any car I've owned.
So, if anyone knows of any kind of stick on protection you can change when it starts looking bad, that would be very helpful
Screen protectors are only meant for surfaces that are touch sensetive, so suseptible to scratches (such as NAV touchscreen, phone screens, iPads, etc...). Do you have screen protector for you laptop or monitor? no! cause you don't need to touch it unless you're cleaning it... and that's when you need to be careful!
Don't take to a carwash. Do it yourself.
I have cleaned my dial covers successfully with a 100% cotton cloth and a quick detailer. I use 2 cloths. One damp with the detailer, and the other to buff off.
alexb makes sense. i only had to wipe my instrument cluster when i had it blessed and the priest sprinkled holy water on them. Used a good 3m microfiber cloth. since then i never touched these dials and the occasional cleaning simply needed a soft brush for removing dust. thats it
1 Post
That is a great solution. Unfortunately it doesn't work for me, since others might/will touch them, e.g. at the car wash.
For the PCM screen, just use a can of compress air to blowoff the dust on the surface, and then use a microfibre cloth (if you have any Oakley sunglasses, the 'socks' that came with them work well) to gently wipe clean the fingerprints.
For the dash instrument panel, just don't touch it like folks say. If needed, just use compress air to blowpff the dust periodically. Another trick I use is to buy one of these cosmetic brushes -- cost only a few bucks at Target. Keep one in the door compartment and just gently brush the dust off of the instructment surface (if it is good for women's face, it is good for our car), it also works well on brushing dust off the gaps throughout the console.
Simple enough.
Are you aware that many car washes recycle their water? So you are getting all kinds of crap (with only the particles filtered out) sprayed into your car with high pressure washers. If you live in an area that salts the roads you are likely to get a saline solution squirted into all kinds of areas of your car under high pressure—areas that ordinary salt on the road would never reach.
Absolutely nuts to take you car to an average commercial car wash IMO.
Thanks for you comments.
A few years ago I decided that I rather spend my sparse free time with my family than washing my car myself which takes more time away from them. I'm ok with the scratches swirls and other things that happen at car washes, but I do like to keep them to a minimum. Hence my original question.
If nobody else has a suggestion to my original question, I guess we can close this thread.
