Occasional clutch slippage
Cabin filter: Look in the trunk on the passenger side. You will have to remove a plastic cover.
Here's a little clarity on the symtoms of a burning clutch. Pretty hilarious...
http://www.youtube.com/watch?v=1Pum3EmN3ec
This has nothing to do w/ SC Sport mode. If the clutch slips on of 3 things happened: (i) you did not release it completely or (ii) there's something wrong w/ the master cylinder hydraulics, or (iii) the clutch is worn.
You know if it is (i) or (iii). If the issue only happened once it could be (ii) hydraulics. Have it checked. Have you flushed the brake lines every 2 years or more often if you track the car?
The cars that did this had nothing wrong with the hydraulic system, nor was the clutch worn.
