bilstein's, lowering and fender rub, oh my...
i will be putting car in the shop for bilstein's this week and i have a concern about fender rub. shop says car will be lowered about an inch from stock after upgrade. i believe my stock wheels are 8" ET57 / 11" ET67 and are the ones i run on the track. i dont think these will be a problem. however, my street wheels are OZ and are 8.5" ET53 / 11" ET65 which means, according to an online calculator, that the fronts stick out 10mm (and inboard 2mm) and rears stick out 2mm (but less 2mm inboard) vs stock.
FYI, all wheels are 19". all fronts are 235/35. BUT all rears are 305/30 (which, since stock rear is 295, already extends outboard and inboard an extra 5mm each, i would assume?)
for those of you who have lowered, did you have any probs with fender rub? can anyone tell just from the #'s above if you think i will have an issue? or does anyone know the limits to where a car can be lowered without causing a problem?
btw, just from looking at the car, the shop says there "most likely wont be a problem" at all, but with my luck...
thanks.
thanks.
Can't answer your question, sorry, but i see you're in MD. What shop are you using? TPC Racing is in Jessup MD and they know as much about suspension as anyone. They are 24hr of Daytona winners.
I have their stage 3 suspension on my car and they were great to deal with.
so, how was the diff betw stock and stage 3...night and day?
the very same - dropping car off thurs. already had their sways and now getting stage 3. yep, best guys in the biz as far as i'm concerned. and like i said, they are pretty sure it will work, just thought i'd throw the question out there to see if anyone else could ease my mind.
no problems,
i have 9+45 12+56 on 245 and 325 tires and lowered 2.5" and fine,
when lowering your concern is the INSIDE of the wheels as lowering the car pulls the wheels in cause the uneven suspension links... your inside clearance on stock wheels is about 1" which is fine, the aftermarket wheels are lower offsets so have 2-3mm more room than stocks.
if you add camber you might run into issues but just lowering and going back to stock alignment or close you are fine.
exactly what i expect when i get the car back (but hearing it from others doesnt hurt my optimism, thanks!)
unsure how much more camber TPC will add in addition to what the car will get simply from lowering it.
but ok, either way, i'm sold - "it will work out just fine!" they know what theyre doing and all will be well. breathe breathe...
no problems,
