Side Mirror Lower Arm Aluminum Trim Installation...
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
I installed my next mod today. Just took me a little over 3 hours. I started with the passenger side first:
I removed the interior triangular trim cover first. There are two tabs on the bottom. Pry it out and up.
The mirror connector will be visible and needs to be disconnected. YOU NEED TO READJUST THE MIRROR TO GO TOWARDS THE CAR AS FAR AS IT'LL GO BEFORE YOU DISCONNECT THE ELECTRICALS. There are 3 torx screws that holds the mirror housing in place.
![](http://i753.photobucket.com/albums/xx179/vinnysca/IMG00186-20100630-1342.jpg)
![](http://i753.photobucket.com/albums/xx179/vinnysca/IMG00188-20100630-1344.jpg)
![](http://i753.photobucket.com/albums/xx179/vinnysca/IMG00189-20100630-1344.jpg)
Remove the mirrors by inserting your fingers and carefully prying it off. It is secured by snaps. It's very sturdy and should not break.
![](http://i753.photobucket.com/albums/xx179/vinnysca/IMG00190-20100630-1350.jpg)
![](http://i753.photobucket.com/albums/xx179/vinnysca/IMG00191-20100630-1350.jpg)
Disconnect the wires to the mirror
![](http://i753.photobucket.com/albums/xx179/vinnysca/IMG00192-20100630-1351.jpg)
![](http://i753.photobucket.com/albums/xx179/vinnysca/IMG00193-20100630-1354.jpg)
The next thing to remove is the motor. In my 2009, there are 3 torx screws PLUS a center screw with tension spring that secures it
![](http://i753.photobucket.com/albums/xx179/vinnysca/IMG00195-20100630-1407.jpg)
There are 4 screws that secures the motor to the motor housing. Remove this and set aside. This will expose the upper and lower arms of the mirror. Two additional screws need to be removed before the entire mirror surround can be slid off and pulled apart
![](http://i753.photobucket.com/albums/xx179/vinnysca/IMG00196-20100630-1408.jpg)
![](http://i753.photobucket.com/albums/xx179/vinnysca/IMG00197-20100630-1417.jpg)
![](http://i753.photobucket.com/albums/xx179/vinnysca/IMG00198-20100630-1421.jpg)
![](http://i753.photobucket.com/albums/xx179/vinnysca/IMG00199-20100630-1422.jpg)
Reassembly is the reverse of removal.
Here are the results
![](http://i753.photobucket.com/albums/xx179/vinnysca/IMG00205-20100630-1532.jpg)
![](http://i753.photobucket.com/albums/xx179/vinnysca/IMG00206-20100630-1532.jpg)
![](http://i753.photobucket.com/albums/xx179/vinnysca/IMG00202-20100630-1531.jpg)
Next up is the illuminated door sills. I need to surf the net for instructions![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Vince
Vince
They are made to look like aluminum but in fact, they are made of plastic. Once I saw them in person , I was like...and they charge me WHAT for plastic? Mark up on these by Porsche are tremendous. But, that's what you get for owning a luxury sports car I guess.
Vince
Vince
Basic Sponsor
Yeah, plastic. We paint these all the time.....
Nice lookin' green beast Vince.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
