PCM Telephone Module Success!
Old Jul 2, 2010 | 09:07 PM
royalpar1's Avatar
royalpar1
Default module
i have it and it works fine not great, as ATT who is the only one with the sim card sucks. i transfer my calls to the i phone when not in the car , all thru the pcm. does the blue tooth work better ?
Old Jul 3, 2010 | 12:58 PM
asu_lee's Avatar
asu_lee
Is the module plug and play?
If I purchased one and installed it does the PCM need to be reprogrammed? Or will it "find" the module?
Old Jul 3, 2010 | 04:20 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
If you install the telephone module (666) you have to have the PCM know to find it.
Old Jul 3, 2010 | 08:15 PM
asu_lee's Avatar
asu_lee
Service code implementation(from the Dealer)? or a DIY?
-Lee
Old Jul 5, 2010 | 03:40 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
-Lee
The dealer will plug in and turn on a particular code for the Phone Module. All PCMs are designed to handle the various options that can be added to the car--but they have to be specifically programed with a 13-digit alphanumeric code to activate and recognize it. (Everyone should have a record of these codes that belong to your car in the event something happens to your PCM. As it is today, if your codes become zeroed out your service center has to email your VIN to PCNA and then they send out the codes that are legitimately assigned to your car to them).
