what size track tires for my 997S?
cbzzoom...the 245-40 and 305-35 in 18" is right at the same overall diameter as stock 19's. This is what I would go with and what I personal use at the track and have for the last 4 years. I did the 255-35 and 315-30 on 18's before and this works out great but the car needs to be lowered.
What you need to keep in mind is that the ratio bewteen the front and rear needs to be with in 4% so that ABS and PSM is not bothered.
"I don't think matching the stock tire circumference is all that important, unless you're really concerned about the accuracy of your speedometer/odometer on the track"
- not at all, but I've heard it's important to get the ratio of front & rear sizes pretty close for PSM (and for the 4WD for me). Not sure if that's true or just heresy / wives tales. I guess if you're racing you're turning PSM off anyway.
.. but on your main point I'm definitely with you, the car is set up out of the factory to understeer, so I'd like to dial that out as much as possible. I think 245/295 might be the way to go.
I've got a set of 18" O.Z. Alleggerita wheels I use for the track. They're light, but I hear they bend easily. I've got about 1,400 track miles on them so far and they're all still round and true. They're dramatically lighter than my factory wheels, for sure. I'm happy with them, and they were cheap. Fronts (8.5") weigh 18.166lbs and rears (12") weigh 23.446lbs.
I run 245/35 and 315/30 Hoosiers on them. Not sure what size would be available for R Comps. I've thought about trying a set of Nitto NT01s just to change things up one of these times.
What is that offset of those 12" allegeritas you got? Or do you have c4 car?
Also turning PSM off on a Carrera or Carrera S or Turbo car does not fully deactivate PSM and it will come back on. I have this happen under threshold braking and into trail braking or sometimes at the exit of a turn....I see the PSM orange light flicker on the rpm gauge telling me PSM was active. I have spoke with Porsche a lot about this and on these cars PSM is never fully turned off.
essentially 12" rim for narrowbody C2 or C2S should have somewhat about 60mm offset, maybe 58mm, but not into other way. And yes it is quite a bummer as I am looking for such wheel for quite a while now without much success.
The stock rear wheels on my (widebody) car are 19x12 offset 51 (with 5mm spacer yielding an effective offset of 46). The 18x12 alleggeritas are the same offset (I use the factory spacer with them).
I shared your aversion to tracking with the spacer, but I figure Porsche probably knows better than I do and obviously they're fine with it.
tirack shows 11" alegeritas for my car with 63mm offset, damon I think wrote me once that 12" allegeritas have 68mm offset so it will require 7mm spacer to run on them but I am not going to buy light wheels to put spacer on them not to say I do not think tracking wheels should be mounted on spacers to begin with.
A really extreme big front option would be :
265/35/18 Diameter: 25.30 in - wants 9.5" rim
295/35/18 Diameter: 26.12 in
ratio : 1.032
the ratios and diameters are good. 265 in the front will surely rub without a lot of suspension work though.
ratio : 1.032
Off sets will change with various wheel widths. For 18" though I would go with 9x18 and 12x18. I believe the front offset is 50 and the rear is 63...John at CCW knows these exact and back spacing too.
yep, i think 50 front is right and for rear axle anything in 58-63mm should sort of fit... with 61 or 63 is probably to be the optimal one.
