Getting in with the battery removed
#31
#32
Sam's Club Energizer Battery group size 49 and sells for $82.28. The CCA is 850. This battery is a little bit longer (~1") than the OEM Moll battery. You have to install the clamp on the last hole in the tray. The hole is not threaded therefore you have to place a stainless steel washer and nut (m8 x 1.25 mm) (w/Blue Loctite) under the tray in order for the bolt /clamp to thread into.
