Getting in with the battery removed
My 997 has been sitting all winter without a battery charger, and I couldn't really put one on it because I don't have power close by in the underground parkade that it has been parked in.
No surprises here, but the battery is dead. I opened the door with the key, and jumped it to get the hood open, and jump started it once with the Auto Club folks coming to jump it.
They left, and I tried it again--completely dead. SO they guy came back so that I could close my door as the window was in the fully up position still so I couldn't close my door.
Well fast forward to about a week ago, where I tried to jump the car with my Range Rover (it has a brand new battery in it)-- no luck. it would sort of turn over, really slow--but would just fade out. Never started.
Im thinking that the battery is likely dead beyond repair. But I have seen others that have come back to life after this type of situation and be brought back to life.
My question is--how difficult is it to remove the battery from the 997, as my tools are a long ways away (i.e. do I just need a couple of wrenches/sockets)?
and when the battery is removed, and I take it into my place and plug it into a charged for say 2-3 days to then test it, how would I reopen the hood (the old procedure using the footwell fusebox jump will likely not work with no battery physically in the car)?
Thanks!
Thanks!
Poseur
Removing a battery is child's play. If you're not too heavy you should stand in the luggage compartment to remove it--as you're really open to hurting your back as you lift it bent over like that.
I replaced mine several months ago and I didn't even bother to photographically document it because it was so easy. You will need a wrench to loosen and later tighten down the hold down clamp, and a smaller wrench to loosen up the terminals themselves. Don't even bother to try to keep power to the car when you do the battery changeover. It's not necessary. Once the new one is in you should be able to fairly quickly clear all of the alerts and warnings yourself.
Do not remove the battery and then close the trunk, or you will have to revert to a mechanical process to open that compartment. What year is your 997? Charging a battery for 2-3 days isn't going to really make a difference if the battery is shot. Just buy a new battery and stick it in. It will take all of 10-15 minutes.
Thanks edgy. It's good to know that I shouldn't close the hood without another battery.
Im trying to get Al Gore out of my nightmares by not buying another battery unless absolutely necessary.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Im just wondering if it is simple enough to do, and the battery comes back to life, no point in buying a new one.
But if it's shot, I may as well buy a new one and was thinking of the optima 925 for weight savings, but don't want it to go dead all the time.
Which battery do you use?/ recommend?
Not an Addict?
I priced Porsche batteries for my 06' 997 at Sam's and Costco. About $85.00.
Big-O tires can order them too for about $100.00.
No need to get the way more expensive ones from the Porsche dealership.
1crazycanuck,
You can use either a H7 from Interstate or any Group 94R battery, both are direct fit replacments. Be careful that most battery reference charts will list the H8 from Interstate or a Group 49-60 battery. They will fit in the battery, but you need to modify the bolt down bracket. Not worth the trouble.
If you're in Canada I would go with either CanadianTire/Partsource (Exide made battery), which carry a 94R for $149. Other option is Wal-Mart (Energizer made by Johnson Controls) for $120. Both have 3yr full replacement and 9-yr pro-rated warranty. I recently installed the Energizer from Wal-Mart (battery # 108-94R) and it works great in my 07 C4S. Actually more power than the stock battery.
I thinks it 765 CCA vs. the stock battery Moell at 675 CCA.
I installed the battery myself. Took me all of 20 mins. Removed the bolt and you will need to tilt the battery forward to get it out from the battery tray. You will see why when you look at the base of the battery.
When you start the car you may get a PASM error. It will go away after you drive the car for 5-10mins
specs on the stock Moell battery (58045) are available here. Note the cross reference to Group 94R battery
http://mollbatterien.com/MollKamina/...A/Default.aspx
The battery in my 06 C2S is not sealed. The plugs are covered by a sticker that was never taken off. I finally got around to opening all 6 and after about a quart of distilled water to fill them up, I put the car back on the battery tender for 2 days. The car still cranks like normal so hopefully this will just extend the life of the OEM part.
If the battery was allowed to discharge to the point that the doors won't unlock or the window won't go up or down you'll have a hard time actually reviving it. The battery should have been removed for the season and put on a trickle charger (would normally be done in the car but due to your predicament isn't possible).
As for sizing, see above. I suggest Canadian tire, but i'm biased. Optima is an excellent choice though but pricey. Have fun!
So you just removed the Two stickers? One of them has Porsche written on it in the Porsche font, and a 99x.xxx.xxx part number on it, but the stickers don't look removable.
But I do see th outlines of the caps underneath the sticker - you know, the caps that have "+" on them, and you could remove them to put distiller water in, in a normal battery
I figure if the worst case is tfat I'm gonna have to replace the battery anyway, $1.28 worth of distiller water seems like a pretty good bet.
How did you peel back the stickers- or dud you just punch through the "+" signs with a screwdriver?
