I Created a Brake Squeal?
Driving for fun, saw a cop. Slammed on brakes (no traffic). Immediately after that emergency ticket evasion technique my left front caliper started squealing. Just for more fun I drove in reverse for quite a distance hitting brakes repeatedly hoping to dislodge debris: nothing.
Sound familiar? Can you actually create a brake squeal by hitting brakes?
BTW, what do I do to get rid of it? A search says spray with brake cleaner. Is that it?
jack up car, take off wheel and swap pads around - they are same.
Poseur
Brake squeal is routinely arrived at by NOT using your brakes in an aggressive enough manner during daily drives. You get a glaze on them that leads to the sound you describe. Suggest you change your foot pressure on the brake by braking late and often for every light or corner. Really press it hard. Occasionally you can pick up a piece of road debris which can lodge between the pad and rotor and drive you nuts until you shake it loose--but it sounds like the dealt with that.
Brake cleaner, essentially dry cleaner fluid--trichlorethelene, is good stuff, but not relevant to solving your problem.
just spraying outside of a caliper is same good as kicking wheels with your foot.
it depends - on my lexus it never goes away by itself even if I speed up to 120mph and then stop dead. only sand paper helps. but it was so with old beaten up rotors, with new rotors it is all back to normal and never makes funny noises anymore - I finally put new rotors on it after 168K miles.
process itself is somewhat like 30min top - but for people who do not like to jack up their cars it may pose some challenge...
