H&R Springs and RSS Spacers OH MY!
Great stance. What a difference a subtle change can make.
[QUOTE=CamsPorsche;7775389]Here are updated pictures. I'm running 295's in the rear not 305's and no rolled arches at all.
Fantastic. I have the same car but an S and have been looking at spacers to fatten out the rear end. Tx for posting.
997 that comes with PASM is a bit lower but it's still not that low. If your ride hops and wobbles, you might want to check your tires, lug bolts, it should not do that.
So now that I have the Carrera 4 with a wider rear end I'm not loving the wheel gap nor narrowed wheel look in the wheel well.
If I run 15mm spacers again I should be fine considering I'm now running 305's right?
Thanks for the info!
I'm wondering now if I should go Eibach or H&R springs as I plan to drive the car in the winter so perhaps the Eibach drop only being 1" would be better?
Cam
Cam
