Oil change on Carrera S's and a Brake Fluid Flush
Old 04-15-2010, 11:47 PM
CHV
CHV's Avatar
Originally Posted by alexb76
Thanks, I was gonna use the same, but I heard this fluid although GREAT with very high boiling points, it needs to be changed more often as it attracts moisture at a higher rate than other fluids?!
Any experience with that?
Have experience w/ OEM, Castrol, ATE Blue/Gold, & Motul. I like Motul the best. Use only a brand new bottle, flush the whole thing through & do it before driving schools. No idea if it attracts water at a more rapid rate or not than others. Think the key thing is new bottle, and doing it before going out on track.
If you are just driving on the street, I'd do OEM and flush annually.
Chuck
Old 04-16-2010, 01:11 PM
cbzzoom
Registered User
cbzzoom's Avatar
Originally Posted by Edgy01
If your housing is stubborn, you have been putting it on too tight. Twist it on until it contacts the seals, and then hand twist it a bit farther.
Yeah, that's another disadvantage of going to the dealer, they cranked on the housing way too tight
Old 04-17-2010, 01:06 AM
CHV
CHV's Avatar
Originally Posted by voda
What brand of lift is that?
It's a Rotary. They make a home enthusiast line called Revolution. US made in Indiana I believe.
Chuck
Old 04-04-2011, 11:40 AM
tcouture
tcouture's Avatar
Sorry for resuscitating an old thread but this one just seemed very appropriate.
I am about to perform a brake fluid change on my 997.2 to change from OE to Motul fluid. Since is it not advised to have OE and Motul in the system (organic vs synthetic), I was wondering what you did for the ABS system and the clutch...
How did you flush those? Or you just did not worry about it? I guess after a couple of changes, they will have flushed themselves but still.I am just trying to cover all the bases before I take the fluid out so I don't run into _too_much_ trouble...
According to what I have found, the ABS system also needs to be flushed using a test tool (like Durametric or PIWIS) to actuate the ABS system while flushing the fluid. Since the clutch uses the same fluid system, I think it would also be advisable to flush it but, since the 997.2 clutch has a return line connected to the bleeder valve, it looks like I will need a special tool to do the job.
I am just wondering about experiences either way out there - flushing or not flushing, particularly when going from one fluid to another.
Thanks,
T.
Old 04-04-2011, 01:47 PM
sullivas
sullivas's Avatar
From my readings and discussions the ABS is normally not actuated every time the system is flushed so you could skip that part. As far as I know (at least on 997.1's) the clutch and brakes share the same fluid, DOT 4 brake fluid. I flush clutch and brakes with ATE Gold DOT 4. It's the same specs as ATE Racing Blue fluid without the dye. IIRC Motul has a higher boiling point hence good for racing. I wasn't aware Motul was synthetic - is this true? If so I'd think it would have a different DOT number.
Old 04-04-2011, 02:08 PM
tcouture
tcouture's Avatar
I think that the DOT standards really specify the boiling points:
DOT 3 Dry= 401°F / Wet = 284°F
DOT 4 Dry= 446°F / Wet = 311°F
DOT 5 Dry = 500°F / Wet = 356°F
Most DOT3 and DOT4 brake fluids are organic (mineral) glycol ether and borate ester based, but Motul RBF 600 is synthetic (according to their litterature). In theory, they would be somewhat compatible in the same system but is not advisable because their performance will be affected.
AFAIK DOT5 brake fluids are silicon based and are a totally different ballgame. DOT4 and DOT5 cannot be mixed.
T.
Old 04-04-2011, 03:27 PM
alexb76
alexb76's Avatar
T.
Don't use DOT 5... not compatible.
ALL other oils you mentioned are DOT4 with different boiling points. Motul being synthetic, not sure about others.
I did a basic brake fluid change to Motul 600, and didn't bother with the rest of the stuff you're trying to do and I've been perfectly fine. I think it does mix *ok* with some leftover oil, but if you're ****, then to be 100% might as well do it.
Old 04-04-2011, 03:57 PM
tcouture
tcouture's Avatar
How did you guess?
In my case, P-Car = Therapy.
T.
Old 04-04-2011, 04:05 PM
alexb76
alexb76's Avatar
How did you guess?
T.
LOL... I think ALL of us on 997 forum have the same condition and are in therapy whenever we step into our cars!
Old 04-04-2011, 04:25 PM
Vjgtrybno1
Vjgtrybno1's Avatar
For 997.1, try NOT unscrewing the filler cap when draining the oil to reduce its flow rate.
Old 03-11-2012, 11:32 AM
mjsporsche
mjsporsche's Avatar
Early start to Spring.
Enjoyed the bonding moment.
Old 03-11-2012, 01:55 PM
Wannabeproracer
Wannabeproracer's Avatar
I use Motul RBF660 in my race car and my daily driver, but both have stainless steel brakelines. higher boiling point, DOT 4 and full synthetic.
Quick Reply: Oil change on Carrera S's and a Brake Fluid Flush
