997 C2S sports chrono question
Old 04-13-2010, 07:23 PM
number9ine
number9ine's Avatar
Originally Posted by quickxotica
Wasn't there a ROW (non-US) -30mm sport suspension option available on the '05 cars? I think the OP may have this suspension (which I believe was a non-active design). I believe this option came paired with an LSD. In which case the car would be lower, handle great on smooth roads, and NOT have a "PASM" button since the suspension is not adjustable.
Open the front hood and copy down the option codes, then enter them in the option code -decoder and you will have your answer.
The 2005 997 US order guide has no mention of a sport suspension or LSD option, if it's a UK option then OP is lucky to be a Brit. Ours were all PASM-equipped by default.
Old 04-13-2010, 07:32 PM
G53
G53's Avatar
Sorry what is an OP?
Old 04-13-2010, 07:51 PM
cab&coupe
cab&coupe's Avatar
Original Poster
Old 04-13-2010, 08:31 PM
quickxotica
quickxotica's Avatar
G53: OP = you :-)
I think I have confirmed my suspicion. See the article below from Nov 2004 issue of EVO (Brit car mag par excellence), mentioning that as an alternative to the standard PASM suspension on the 3.8L 997S, Porsche offered European customers a "sport suspension" option which deleted the "active" dampers in exchange for lower, harder springs and traditional matched fixed-rate shocks. This option was not offered to us hayseeds over here in 'merica.
http://www.evo.co.uk/carreviews/evol...carrera_s.html
This may be how your car was specced from the factory. If so, rejoice!
Old 04-15-2010, 03:50 AM
G53
G53's Avatar
right so it has the wires coming out of the rear of the "shock housing" and fairly thick metal pipe spanning between the two which i presume is the hydraulics for the PASM. So hopefully this is correct?
i wonder therefore whether mine is all linked in to the sport button. I may repost with a more specific title to cast the net wider...
thanks again for assistance everyone
Old 04-15-2010, 04:21 AM
alexb76
alexb76's Avatar
I wouldn't worry too much as EU cars were optioned differently and with more flexibility, so I suspect, PASM was NOT standard on 2S cars in EU and therefore didn't come with this car!
If it is standard, then maybe this was the sport suspension option with PASM delete!
Old 04-15-2010, 05:16 AM
Edgy01
Poseur
Edgy01's Avatar
The lower suspension was not offered on the US 997.1 cars. It was finally available on the 0997.2 cars. Porsche (correctly) knew that US roads are not up to par to support such a lower suspension.
Old 04-15-2010, 01:52 PM
Ferdie
Ferdie's Avatar
Hello,
judging by your description your car most likely features the optional -20mm sport suspension. Option code is P17 and should be listed on the car´s identification sticker (underneath the front hood, I presume). The car is stiffer but more communicative and, as a highlight, comes with a mechanical lim.-slip differential. Unlike the 997.2 models, the stiffer sport suspension is entirely mechanical and therefore misses the center console switch.
Old 04-15-2010, 01:57 PM
alexb76
alexb76's Avatar
Originally Posted by cab&coupe
Original Poster
Man, u gotto change ur avatar. For the sake of all other rennlisters!
Old 04-15-2010, 05:16 PM
At Law
At Law's Avatar
Originally Posted by G53
i can't say i feel the ride harden up when i hit the sport button, but several friends have said it can be difficult to tell. When i took a friend's S for a test drive i couldn't feel the difference in ride quality but I could feel the throttle response change.
When I hit the PASM button on mine, I can immediately feel a difference
in the suspension and my fillings in my teeth start shaking loose.
In fact, I can very rarely use it on these damn rough Midwest roads.
Old 04-15-2010, 05:36 PM
robbonds
robbonds's Avatar
i only use when i know i am gonna take a bunch or corners..otherwise i dont see a reason
robbonds
robbonds's Avatar
but i always use sport...only occasionally use sport plus
Old 04-18-2010, 05:10 AM
G53
G53's Avatar
OP here: as i don't have the original booklet and therefore sticker with codes, I have written to Porsche for an identity and options check. However in the meantime I was hoping to receive some comments on the wiring that runs into the suspension and the metal pipe as previously mentioned, which can be seen when you take put the plastic covers on either side of the batter cover. If this is not PASM is it the ABS??
Old 04-18-2010, 01:11 PM
LlBr
LlBr's Avatar
FWIW: check wire for USA .1 cars.
Old 04-18-2010, 05:15 PM
G53
G53's Avatar
thanks lblr. mine doesn't have the wire coming straight out the top of the shock, more to the rear of the well. so that answers that! thanks again for your help
Quick Reply: 997 C2S sports chrono question
