P0028 Bank 2 valve lift control final
Old 04-11-2010 | 05:01 PM
justatoy's Avatar
justatoy
Default P0028 Bank 2 valve lift control final
My car has been sitting for 5 months for winter.
I just removed a supercharger set-up from my car and had the DME reprogrammed back to stock tune.Started it up and this code popped up....
P0028
I did a search and couldn't find any info.
Any help would be greatly appreciated.....
Thanks,
Stacy
Old 04-11-2010 | 05:10 PM
utkinpol's Avatar
utkinpol
P0028
Thanks,
Stacy
google gives this - may be relevant, even if it`s subaru? all those codes are unified these days. check all the wiring - may be you simply tore that connection to solenoid?
http://www.subaruoutback.org/forums/...&postid=201052
renntech folks suggest incorrect flash version? See last post:
http://www.renntech.org/forums/index...howtopic=26802
Old 04-11-2010 | 05:17 PM
justatoy's Avatar
justatoy
Yeah read that.....all wires are OK.
I also read that it could possibly be in the re-tuning.
BUT found this interesting...
POST#11
Stacy
Old 04-11-2010 | 05:34 PM
utkinpol's Avatar
utkinpol
POST#11
Stacy
if you are sure you have original stock ecu flash and all injectors/solenoids are fine - disconnect battery for 10 min and try again - will it throw new code or not?
Listen to the engine - does it sound/vibrate just as before? stock ecu throws more codes than any aftermarket flash - it`s a fact.
Old 04-11-2010 | 05:40 PM
justatoy's Avatar
justatoy
Idles SMOOTH...no vibrations at all.....I tried to clear the code with my Durametric and it came back.
Injectors came out of a running car.
My fuel is 5 months old BUT can't see that as the problem that would throw this code...
I am going to try and disconnect the battery again.....
Stacy
Old 04-11-2010 | 05:54 PM
utkinpol's Avatar
utkinpol
Stacy
worst what could happen is if you got dirt inside somehow and it got stuck somewhere but any crap in fuel line would be immediately noticed as engine would not run normal. if it`s not knocking and sounds perfect as before - most likely everything should be fine. when valves have issues - you can always hear that right away.
but who knows. 997 has a very elaborate sensors system and if it throws a code - there is a reason for it most likely.
if you flash with softronic - call them. or vividracing. they probably should know something about those codes first hands if it is in any way related to new flash.
I flashed my softronic back to stock once and it did not give me codes but it proabably may not be the same with what you did...
Old 04-11-2010 | 07:09 PM
justatoy's Avatar
justatoy
Well....when in DOUBT go back and check the connection and BE SURE IT IS PLUGGED IN..!
Thanks to Karl(Porschedoc) for helping me understand what/where this was.
Stacy
Old 04-11-2010 | 08:17 PM
utkinpol's Avatar
utkinpol
Thanks to Karl(IAPorschedoc) for helping me understand what/where this was.
Stacy
so, what was it?
Old 04-11-2010 | 08:54 PM
justatoy's Avatar
justatoy
Forgot to plug in the solenoid down by the spark plugs that controls the valve lift.
Stacy
Old 04-11-2010 | 08:56 PM
JohnnyBahamas's Avatar
JohnnyBahamas
Aren't DTC's cool?
They know things.
Old 04-11-2010 | 10:55 PM
PorscheDoc's Avatar
PorscheDoc
Stacy
Just PorscheDoc here IAPorscheDoc on 6speed because someone stole my name and then didn't use it, hahah.
Old 04-12-2010 | 01:55 AM
justatoy's Avatar
justatoy
Sorry Karl,
Correction made,LOL!
Quick Reply: P0028 Bank 2 valve lift control final
