Venture Shield install question
Had a full front Venture Shield bra installed on my 3 week old meteor gray 997. I choose the Venture Shield for its lack of orange peel and sheet width so the full hood could be covered. I had 3M installed on the bumper of my last car (about 6 years ago) and never liked the orange peel and endured the hood and front fenders collecting chips anyway. Did some installer research and picked a shop that was well recommended (on the web) and the guy seemed experienced and confident about doing a full custom install on my brand new vehicle.
Well…dropped the car off and picked it up later that day. It was parked outside in the sun, and as I walked up to it I first thought perhaps he didn’t get to it - the Venture Shield is very clear an shiny! As I got closer I began to see swirls in the hood, so I knew something was different. The installer walked out and seemed quite proud of his work. As I closely inspected the install, I did note all of the edges and gaps were precisely cut. I mentioned the swirls to him and he said he could “buff them out” after the film cured. Further examination revealed several marks within the film on nearly every piece including the major hood and fender pieces. The installer dismissed them as not significant and said that they would disappear as the film cured. I’ve since done more research, and I would say they are more likely stretch marks and adhesive issues that aren’t going anywhere ever!
I guess what I’m asking is what level of perfection should I expect and demand? Since this is a brand new vehicle, the paint which looked great at any distance now has some clear film issues visible from about 5’. The casual observer from 10' or more would still consider the car “perfect” and likely not even notice the flaws. I understand the challenges of this install and the work was certainly respectable, just not “perfect”. I am also skeptical about his buffing out those swirls.
Am I being overly **** or should I be demanding a redo or refund? Some of the install pics posted here look absolutely perfect, and I could certainly find angles where my install would appear perfect in a digital picture...
As Edgy01 mentioned, take some photos and put them up here so we can see what is going on.
PREMIER PROTECTIVE FILMS (In Business since 1997)
ClearGuard Alpha G2 PPF - Most hydrophobic ppf on the market
SatinGuard PPF
Spectra PhotoSync IRD - Highest heat blocking window film in industry
Authorized Modesta and Nanolex Dealer
Checkout our Youtube Channel!
Premier's Youtube
B: 510-623-1308
42630 Christy St, Fremont, CA 94538
sales@premiermobilegroup.com
http://www.facebook.com/premierprotectivefilms
SatinGuard PPF
Premier's Youtube
B: 510-623-1308
As you know, VS has a lifetime warranty and advertises "Invisable". Further, everyone stresses that the installer is the key, regardless of which film you are using, and it sure sounds like an over-stretch problem. So.......you should not have to jump through hoops . Below find a comment from the Corvette forum in January:
"Had VS installed in early 2005 and absolutely no problems...but key is the skill of the installer (another Vette driver I know has VS installed but installer was a hack...totally crap look since film was overworked and stretched). Most pleasant comment by someone is they did not even know my Vette had a clear bra. "
The fact that it bothers you tells me that it is not a perfect job. I just had a full car wrapped in ventureshield done by Metropolitan detail. It is absolutely flawless even from 2 inches you cant tell that there is a film over the paint. No cuts on the paint. No wrinkles, swirls or stretch marks on the clearbra. The marks you see on the film could be fingerprints, trapped dirt or excessive stretch marks from the adhesive getting distorted by a mediocre installation job. Site sponsor Premier(the best in this business) can easily diagnose the problem for you if you can post the pictures. The swirl marks are probably from a final clean up job done using a cheap microfiber towel and could probably be buffed out by the least abrasive polish. I will personally not tolerate anything but a near perfect job on my car. Show us the pictures, if they are bad I would demand a reinstall and if its not that bad but nowhere near perfect then may be ask for a 15 to 20 % discount.
The VS install on my meteor gray 2009 has only one small bubble caused by a piece of lint. Also, it is very hard to make a proper fit around the front bumper radius and I have one area where there is a linear distortion. That is all on a full front kit! Otherwise, you can't see the shield. From what I have seen, you cannot remove swirls or scuffs from the material. I hit a cardboard box on the freeway and it scuffed my VS cover on the bumper. I have tried everything to remove it with no luck. But, it is better than damaged paint!!
This is interesting, identical write up but using a different make and colour:
http://www.m3post.com/forums/showthread.php?t=361062
Bizarre indeed.
