Decoding your VIN: Each digit means something
Old Feb 6, 2010 | 02:27 PM
nicoff's Avatar
nicoff
Default Decoding your VIN: Each digit means something
I found this site that tells you what each digit of your vehicle VIN means:
http://www.vinguard.org/vin.htm
This applies to all vehicles being manufactured.
Take a Porsche VIN number: VIN # WP0CA29925S7XXXXX
The first three digits (WP0) tell you the country of origin and manufacturer
W=Germany
P0=Porsche
Next 5 digits (CA299) tell you the manufacturer's vehicle descriptor, in this case:
C=Cab
A=normally aspirated (?)
2=safety code (air bags?)
99=the first two digits of the model (third digit comes later)
Digit 9 is a check code generated by a formula
Digit 10 is the year of the vehicle, in this case, 5=2005
Digit 11 is the assembly plant code, in this case S=Stuggart
Digits 12-17 is the vehicle identifier section.
Porsche uses the 12th digit to finish the identifying job they started earlier. In this case the used "7" to complete the "99" that they used in the vehicle descriptor. So this car is a 997.
The 13th through 17th digit are the production serial number.
Old Feb 7, 2010 | 04:12 AM
CamsPorsche's Avatar
CamsPorsche
Yup makes sense...coupes will be "A" designation as per my own VIN
Old Feb 7, 2010 | 06:07 AM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
It used to be so much easier years ago. A friend of mine's 1973 911 Targa is VIN 9113111111. 911 for model type, 3 for 1973, the next 1 for Targa body style, and the last 5 digits for the serial number of that body. Neat number! All this changed around 1978-80.
Old Jan 18, 2012 | 05:02 AM
James Herne's Avatar
James Herne
All Porsche chassis numbers explained, the 5-digit, 6-digit, 8-digit, 9-digit, 10-digit and 17-digit:
http://stuttcars.com/technical/vin-decoder/
Old Jan 18, 2012 | 04:51 PM
kkswow12's Avatar
kkswow12
Default what about the ZZZ in some #'s
i think they use this in germany, or maybe it is europe, mine has this for #'s 4,5, and 6,, woops, just saw the other window with total explanation, mystery solved
