PCM issues
Old Feb 3, 2010 | 09:25 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
I tried the frequency issue that you describe--being unable to choose or scan to "640" mHz. As someone else suggested, if the PCM thinks the unit is being used in Europe. As you can see, it is going to the discrete 640 freq for me.
File Type: jpg
File Type: jpg
Old Feb 3, 2010 | 09:39 PM
KeninBlaine's Avatar
KeninBlaine
Thanks. Mine shows the freq range from 531 to 1620 KHz, again interestingly multiples of 9. My language is set for English US. Haven't found any other user setting that would direct it to the North American standard. Hopefully the dealer can activate the right settings to get everything back on track.
This car was CPO'd in November or early December, and then sat in the dealership used car showroom for a number of weeks and the battery did get drained at least once because of sitting too long. I have to wonder if that may have caused these anomolies, as I would have thought the CPO process would have found any problems if they existed then.
Old Feb 3, 2010 | 09:50 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
It's my understanding that the footwell lighting is a part of that function. Several months ago my PCM was replaced and it wasn't until I noticed that I couldn't get my footwell lighting to come on at all that I went back to the dealership and bitched to them.
They queried PCNA for the MMI Enabling Codes for your VIN. What is SUPPOSED to happen when a new PCM is installed is that the enabling codes are supposed to be transcribed into the new unit. (My guess is that a PCM was replaced on that car).
You should have all the enabling codes transmitted to your dealership from PCNA. Have them burn a copy of them for you so that you can keep them in your manual in case they screw up again.
Here's what's going on: These cars are so complex that the "technicians" are having trouble knowing everything about the cars. As owners, we have to be proactive to ensure that what we paid for is delivered. The PCMs are quite sophisticated and have the capability to do everything potentially, if the right activation codes are plugged in.
In my car, for example, my enabling codes include that for:
(1) Communicating with the remote CD player
(2) Individual memory (a part of the Sports Chrono)
(3) Off-Road Navigation (aka Extended navigation)
(4) SportChrono MMI
The codes are 16 digit alphanumeric strings that the PCM receives to activate those particular functions.
The codes are linked to the VIN of the car. Insist upon seeing those codes and get yourself a printout which you should keep with the car. With their fancy programmer in the shop, they plug them in and then you're good to go!
INSIST upon that service center having those codes in their hands before you arrive on Saturday. They can only get them from Atlanta (PCNA)
Old Feb 3, 2010 | 11:09 PM
Bijan's Avatar
Bijan
Was planning to get all the software updated at the next service by PIWIS connection. Is there a risk that this will:
set to nominal/turn off
some preferred existing functions?
Old Feb 3, 2010 | 11:20 PM
TooSixy's Avatar
TooSixy
Anyone knows if there is a key generator for those codes?
Just kiddddinnnngg...
Old Feb 3, 2010 | 11:52 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
It should not. The service facilities are bound to match the codes to the VIN.
Old Feb 3, 2010 | 11:58 PM
Bijan's Avatar
Bijan
Thanks Edgy, makes sense
Old Feb 4, 2010 | 12:56 AM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Here's what I see on my in-dash display--
(a) TPMS (usually it shows 33 39 and below 33 39) (changed wheels so it's learning)
(b) remaining range in miles
(c) miles per gallon since reset
(d) average mph since reset
(e) Navigation information (range to next turn point)
As you can see, radio information shows up on many of these displays, above the miles/mileage figures.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Feb 4, 2010 | 01:29 AM
schwartzwest's Avatar
schwartzwest
I don't remember seeing the navigation information in the instrument cluster disply. I will have to check for that...
Old Feb 4, 2010 | 01:31 AM
aggie57's Avatar
aggie57
Dan - is that a mic sitting top right on the steering column?
aggie57's Avatar
aggie57
If you dont have navigation active it will say ... "Navigation not Active"....
Old Feb 4, 2010 | 01:32 AM
KeninBlaine
It is the CDS display line that is missing in my car. This is where the radio station or CD track info is displayed unless you're using Nav or TPMS (which my car doesn't have).
Old Feb 4, 2010 | 01:35 AM
schwartzwest
I don't recall ever seeing that message either...
Old Feb 4, 2010 | 01:41 AM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
That's a mike to my Tooki installation (non-factory Bluetooth).
When I have driven a friend's 06 997S I don't seem to see as much information on his either! There's a lot of information available there.
Perhaps you have to turn on the CDS information. Sometimes it even has the song and artist displayed when listening to the radio (997.1) and the station is transmitting that stuff.
Old Feb 4, 2010 | 01:45 AM
Fin Fever's Avatar
Fin Fever
I am still learning about this stuff, Why do you prefer 33 39? I am always OCD about sticking to the factory 37 44 when cold for my PS2 s.
