Wheel Confusion...
Wheel Confusion...
Can anyone confirm that these wheels will fit my 05 997c2 with no problems? I think they may be C4 wheels but I'm not sure. In the picture the rear wheels seem "dished" more than my current wheels. I thought C4 wheels were all 19".
Any help would be appreciated as I'd hate to buy them and find out they don't fit properly. Thks...
Wheels and Tires Details:
Front Wheel: Part #: 997-362-136-00 Size: 8.0Jx 18 Offset: 57 Front Tire Size: 235/40/18 Michelin Pilot Sport. Speed Rating 91Y. Tire Tread Remaining: 98%.
Rear Wheel: Part #: 997.362.142.00 Size: 11Jx 18 Offset: 51 Rear Tire Size : 295/35/18 Michelin Pilot Sport. Speed Rating 91Y. Tire Tread Remaining: 75-80%.
Per the manual the fronts are an exact fit. The manual doesn't show an 11x18 option for the Carrera or S, the 10x18 has a 58mm offset and the 11.5x19 has a 67mm offset. The wheel you ask about will be pushed out in the rear, but I can't tell if it will rub against the body.
The front tire size is fine, but the rear is under-rated. Spec for the rears is 101Y (18 inch), 100Y (19x11) or 102Y (19x11.5). All three should be XL as well. The only "lesser" rated tires are the snows.
fronts i run 8.5+48
next set of wheels im going 8.5/11.5+44
Thanks guys....I think...
I did a thread search on this topic and the results were pretty much the same.
Some say you can , some say you can't. I guess it will cost me $2000 to find out...
Newbies Hospitality Director
I guess I should have been more specific in my comment. They will fit on your car, but they will not fit properly (a.k.a completely inside the wheel well) on your N/B C2.
If you want a cheaper alternative to finding out if you like the way they would fit, buy a set of 15mm spacers and install them on your car (will also need longer bolts). Then you can judge for yourself if you are comfortable with the fit.
difference between 11+51 and 11.5+48 is 9.35mm, so even if you argue mine are not "flush" as i say they are but still UNDER the fender... the wheels he is looking at are 9.35mm further in than mine, couple that with the fact i have 305 and he will have 295.. thats 14.35mm further in on the tire (the par that actually matters)
my car is lowered however, around 30mm from non S stock susp.. so around 10mm lower than sport pasm, or about the same as GT3
rijowysock
What's that old saying? A picture is worth a thousand words...
Thks for that. It looks like I should have no trouble if your experience is taken into account.
I am running 15 mm spacers on my 67mm rear 11x19 OEM Carrera S rims on my 09 Carrera S, and they fit fine - maybe just a hair wider (2mm) than I prefer vs. the fender although they look fine. I would say the 51 mm will fit if you don't mind them a hair wider
Do a search here and on the other boad about Turbo offset/rims on a narrowbody. They do work and you'll find pics. You can also see pics of my spacers in a search that will help you with what a 52mm offset looks like
Chris
Chris
rijowysock, I've never seen meisters on any P-car!! they look awesome and I think you have perfect offsets which makes the *** shot look that much more aggressive. Beautiful car you have!
The jury is in and the verdict is....they fit!!!
Wheels arrived yesterday and I put them on right away. Lots of clearance on the inside and they do not protrude on the outside. That is one pile of rubber meeting the road.
