Softronic??
It also helps to disconnect power - drop off negative wire from battery - for 10-15 min after each change to exhaust/intake - re-learning process will be faster this way.
Got it...
BTW - I got the car back from the dealer this weekend! I am stoked.. I learned this Saturday that it has an Aasco aluminum flywheel. Which would explain the (Moderate) "sport bike" like throttle response. I have never driven a stock 911 of any year so I have nothing to compare this one too.. But something just didn’t seem normal about the acceleration etc. Couple the flywheel with the solid motor mounts and you get a ton of feedback, which I like even for street driving.
Thanks,
Steven
I sent an email to Softronic on the weekend and they have responded this morning - great response time!
In response to your questions, yes, Softronic can turn the Sport mode on for you from our end. It would be on all of the time and does make the throttle response more sensitive.
As to refunds, Softronic does not offer refunds as our software provides a good increase in hp and torque. We do not offer "trial ware" as some companies do as this will permanently alter your DME and if your car is under warranty, it will void the warranty coverage.
Now my question is, since I have a 997S with Tip S, if the shift maps are not altered, the Tip S will still shift somewhere in the under 3500 RPM range, does that mean I won't get much benefit from Softronic?
