Damn - just kerbed a wheel at 30-40mph
Hi. I just kerbed the passenger side front wheel of my C2S at 30-40mph on a "chicane" whilst on a "spirited drive" this afternoon. Apparent damage is 25 cm grinding of alloy wheel rim, which looks as though it will sand, fill and paint away, and 1 mm strip on edge of tyre peeled off, but no obvious damage to main sidewall. It looks as though the tyre took the impact first and then the alloy at a glancing angle. Frankly it looks no worse than a parking misjudgement.
The car drove 10 fast, twisting miles home without obvious ill-effects (I took it much easier than normal, keeping within 30-50mph) but, given the speed of the impact, I'm concerned about hidden damage.
Apart from the obvious advice: take it to the OPC to check the axle, steering, alignment etc, has anyone got any tips as to what I should look out for in the time before I can get it checked?
Thanks guys
Thanks guys
Ouch! I guess the "glancing angle" aspect is good. Nice to hear you're not too upset about getting the wheel looking normal again. Drive home was good. Heck, I bet after a little alignment adjustment you'll be fine.
Yeah. Just taken a second look and rear wheel is also badly scuffed around most of the rim (tyre looks fine) - hadn't noticed that at first as the impact was felt at the front. That'll teach me to drive in slush with Sports Chrono on (PSM mildly-disabled). Must have skidded into the kerb.
I'm comfortable detailing my wheels, it's a bent axle that would worry me.
You may find that the wheel is slightly bent (in addition to the cosmetic damage you mentioned). I hit a curb hard with my previous car (E46 M3) and I got the vibration at speed. I took it in to get the wheel balanced, and they could not properly balance it because it was out of round. I ended up replacing the wheel after living with it for a while.
Thanks guys
Thanks guys
First time I ever did this in my Porsche. P*ssed me off. I'm usually very very careful but was up way too early and just forget where I was in the lot.
Sincerely,
Macster.
Poseur
Take a critical look at the tire. Watch for bulging in the sidewall which sometimes happens with a hard strike, breaking internal cords. Just keep an eye on it.
I did something similar awhile back and the problem was strictly cosmetic. Had a couple wheels redone. It's not particularly expensive (for the majority of wheels.) For the Carrera Sports it's more as the finish is machined, while the others (save the forged) can be filled and painted.
Best of luck. Sometimes, too, it may be simply cheaper to purchase another wheel, particularly if the wheel is no longer true.
Thanks for the input guys.
Fortunately my OPC can perform an alignment tomorrow morning (I thought it might be much longer - there's been so many ice- and snow-related accidents in the UK this month) so I'll ask him to check for tyre integrity and wheel deformation as well as axle damage at the same time.
Update
Had an alignment done today, as recommended by a few of you, and the wheels were well within original tolerance. Axle, suspension, tyres all passed fit.
That car must be pretty well screwed together because the rear wheel looks like an alligator has been chewing it.
All it's going to cost me is £130 ($200) for repairs to two wheels + the alignment costs, but the latter has given me peace of mind, which is a currency that continues to appreciate with each passing day.
