Fusebox - where to tap for an extra circuit?
Old 01-16-2010, 12:20 AM
Mike in CA
Mike in CA's Avatar
Originally Posted by keninirvine
The AWD on my 07 Targa didn't have the electronic control for the AWD. That was introduced on the 09 model AWD cars.
See my corrected post above. Guess your C1 would have been available in any event being a 2007.
Old 01-17-2010, 11:57 PM
BlueJay73
BlueJay73's Avatar
"fuse taps," "piggy back connectors"--where do you get these things?
Old 01-18-2010, 01:07 AM
Mike in CA
Mike in CA's Avatar
I called the little brass colored item in the picture a piggy back connector, but the packaging says fuse tap. In any event, the picture also shows one "piggy backed" to a fuse. The fuse just plugs back into the circuit (preferably unused)you want to use and the connector is available to "tap" for power to your radar detector or whatever. I bought these at Radio Shack.
Old 01-18-2010, 02:25 AM
YA911Fan
YA911Fan's Avatar
I got mine here. It's really an elegant solution... (BTW, this one is different from the one pictured above)
http://shop.tsisecuritycorp.com/main.sc
Old 01-18-2010, 10:35 AM
KeninBlaine
KeninBlaine's Avatar
I got mine at PEP Boys. It has the fuse with a wire lead coming out of it.
Old 01-18-2010, 12:23 PM
stevepow
stevepow's Avatar
Fuse Tap at NAPA - had wire coming out as well and I found matching connectors for my Passport wiring at Radio Shack so I didn't have to mod anything (other than the Fuse Tap) to connect it - all can come out and be same as new.
Old 12-04-2011, 10:45 PM
oh58driver
Registered User
oh58driver's Avatar
I'm on a business trip and want to get ahead on the project and get the ‘add-a-fuse’ before I get home. Anybody know what type of fuse box a 2009 C2S has. ATC,ATM or other?
Old 12-05-2011, 02:36 AM
Edgy01
Poseur
Edgy01's Avatar
Tread carefully when you mess with the fuse box. Don't do something that will end up looking like a kluge job. Make it look like something that fits inside a $100,000 car.
Old 02-05-2012, 06:24 PM
BuddyK
BuddyK's Avatar
Is there a ground that's easy to find near the fusebox?
Old 02-05-2012, 11:50 PM
Mike in CA
Mike in CA's Avatar
There's a piece of carpet trim surrounding the fuse panel. Remove that trim and you will find locations where screws are secured to the body and will be suitable grounding points. You will have to pull off the door weatherstripping to remove the trim and can't remember if there are any screws; it may just snap in place, but it's obvious when you look at it and it's easily done.
Old 02-09-2012, 12:21 AM
fskof
fskof's Avatar
Here is a link that I found that has some good pics
V1 hard wire w/o splicing with pics
Old 02-09-2012, 07:03 AM
gota911
Newbies Hospitality Director
gota911's Avatar
You forgot to add the link.
Quick Reply: Fusebox - where to tap for an extra circuit?
