X51 Headers redux...
So, 200 cell cats with stock mufflers improves sound, and possibly performance, without beeing too loud.
Question;
If possible, I'd like to loose some weight by swaping out stock mufflers for something lighter without substantially increased sound level. Any recomendations?
Question;
Moderator
I wouldn't bother swapping mufflers to save a few lbs. The cats and headers are where the gains can be found and you'll find X51 headers and 200 cell cats save quite a bit over stock. The sound is "just right" with that setup. I think any aftermarket muffler is going to be VERY loud with the headers and cats.
The after-market AWE cans (with headers and sport cats) were not louder.... just different.
Maybe other mfr's cans would give different results, but this was my experience with AWE.
Moderator
Hmm, that's opposite my experience. I had the full AWE headers, cats, and mufflers on my 997.1 and it was "ear bleeding" loud. So much so, I took the mufflers off and put the stocks back on, which helped greatly. I later swapped out the X51 headers for the AWE headers and the sound was the same - Goldilocks "Just Right".
Ron I would have thought the same, however after having the full AWE system with 2 versions (over time) of their muffler cans, then reverting to stock cans.... the stock cans were quite loud, but with a completely different tone and sound. To the point where I was asked at a couple tracks... "Sounds great but did you really pass sound test?" .... which I did BTW!
Dave
Ok, thanks for sharing pictures and experiences!
Re swapping mufflers I thought of the european tuners that often have "TÜV approved" versions (=less SPL) of their regular ones; Cargraphic, FVD/TechArt etc. I didn't know what to expect re weight loss. If it's only a few lbs then I'll pass. Would like it to be at least 15+ lbs. But, maybe that's unrealistic.
First step taken though. Had the car at my dealer for other reasons and "accidently" got a set of X51 headers with me. Had decided on equal length but will try these first.
Question;
Anyone knows if a (dyno) comparison has ever been done between X51 and an aftermarket equal length type? If possible, I'd like to know what's to be gained by going to AWE, Cargraphic, Tubi, FVD/TechArt, Borla, Fabspeed, Milltek etc. There are so many out there! Same with sport cats, AWE, Cargraphic, Milltek, FVD/TechArt, APR all have stuff for these cars.
Thanks,
Question;
Thanks,
Thanks Dave,
-Is it worth upgrading the C2 headers? I see/ think I understand why the C2S headers are not as efficient, as the x-51.
How do the x-51 headers compare to C2 headers? and/OR FVD/AWE ?
If i'm not mistaken wasn't the x51 pkg used on the 3.6 anniversary model?
I asked this in my other thread too, but let me summarize my understanding...
If I got X51 headers, PLUS PSE... what sort of changes should I expect? From what I gathered here:
- More breating in mid-range
- MAXIMUM 3-5 HP gain
- Much better engine/exhaust sound
Is that right? Also, I assume the header install is a relatively easy job, specially if you're doing exhaust at the same time, right?
Thanks Dave,
Dave
