Boiled socks smell from A/C
Not that I regularly boil socks.....but every time I turn on my a/c, the car smells musty for a bit until it clears up. I remember hearing about a filter that is replaced periodically that will clear this up. I had the 2 year inspection on schedule last year & it still has that funky smell. Any suggestions? Thanks.
Next time, turn the AC off 2/3 miles before you shut off the engine for the day and turn the ventilation up during that time to dry up the vent pipes.
CAn take as much as 24 hours without the blower running.
I had a similar issue with my Audi S4. When the smell would start I ran the heater to dry the evaporator. It worked for about 2 months then it would come back.
Good luck!
Good luck!
we also had this problem with our Audi, the service manager used an Ionizer contraption that cured the issue completely, (after 3 visits first for cabin filters) I would call your service Mgr, and ask him about this process.
Good luck
Good luck
You may want to call Wurth and ask them which product to use:
https://shoponline.wurthusa.com/wurt...log/group.jsp/
or
or
I'll give it a try. The temp here in the desert has been on the mild side. I've had the a/c off for the last few days & have had the windows/sunroof open. What a treat! NO AC!
Nothing, NOTHING, works long term other than parking inside with the windows down or sunroof open each and every night or the airsept device.
Oh, one other possibility...NEVER run the A/C.
I bought a Nuvonair ozone generator and used it in my wife's car that had the moldy air conditioner smell. I left it on with the air on recirculate for about a half hour and then turned the car off and left it on and in the car overnight. It cured the problem.
I had a similar problem in my old Audi TT after my girlfriend shot the contents of her stomach (Legal Seafoods fried clams) all over the car and into one of the vents. It stunk as bad as that relationship was.
I solved the problem by selling the car.
