Need advice of clear film paint protection
Shark Slayer
Location: 'BETWEEN NORTH STAR BOROUGH...& THE CONCH REPUBLIC'
1 Post
Just What the Doctor Ordered! ;)
Thank you David for getting back with me. I will look into your suggestions.
Guidance appreciated.
Kim
We cannot stress this enough. Quality should be the #1 concern when it comes to an aesthetic mod. If quality is overlooked and pricing becomes too much of an issue, this might not be a good option for those interested in protecting the paint. In this case, paint protection film, should be rather "clear". Too often, would consumers believe that quality is equal with all providing the service.
Below are some photographs of a poorly installed clear bra on darker colored Cayman. The previous clear bra installer made 2 attempts at the application and the results are below
PREMIER PROTECTIVE FILMS
ClearGuard PPF Specialists, Spectra PhotoSync IRD & CeraLuxe IRD, Authorized Modesta and Nanolex Dealer
www.facebook.com/premierprotectivefilms
B: 510-623-1308
sales@premiermobilegroup.com
See Our Projects! http://www.facebook.com/premierprotectivefilms
CLEAR BRA CLEANER -TRACK MARKS ON CLEAR BRA - PF1 TTR!
http://www.premiermobilegroup.com/pf1_products.shtml
B: 510-623-1308
This is just an example of scores of poor instlalations we see annually. In this case, not only was the clear bra pretty visible, the previous installer also put some pretty deep razor cuts into the paint. This is over an installation that costed 20% less than ours.
Keep in mind that the newer and less experienced clear film installers rely on lower pricing to obtain work and experience. For this vehicle, there was more damage created from the razor cuts than rock chips had there not been a clear bra installed
We would like to stress this again. For those looking into paint protection film installation, please do not rely solely on pricing. This is the area where you truly get what you pay for. In the case of the Cayman above, there was extensive polishing that took place to remove most of those deep razor cuts. The previous installer told this customer that he has X amount of experience and can produce the same type of results as us. It is quite obvious the results.
Below are pictures of our installation replacing the poorly installed clear bra.
